Results 1 to 16 of 16
Thread: How Far Away Can My Super Pump Be?
    Jun 2011
    Michigan
    41
    I am in the process of purchasing and burying a 24' round Radiant Metric GT Pool. They are giving me a 1 HP Hayward Super Pump. The ideal location for me for the pump would be about 35 feet away from the skimmer. Will that be ok?
    24' x 52" round Radiant Metric GT, Fully Buried.
    Re: How Far Away Can My Super Pump Be?
    Yes, that will be fine.
    Jun 2011
    Michigan
    41
    thanks, does pipe size matter, I was planning on using 1.5".
    2" is better and doesn't cost much more, but 1.5" will work.
    If possible, you might want to consider using a 1/2 HP or 3/4 HP pump instead of the 1 HP.
    Support the site
    mas985's Avatar
    Pleasanton, CA
    11,743
    The 1 HP SuperPump is smaller than many other 3/4 HP or even 1/2 HP pumps so it is actually about the smallest IG pump on the market.
    Mark
    Quote Originally Posted by mas985
    This shows the SuperPump in a 1/2 HP and 3/4 HP model.
    Support the site
    mas985's Avatar
    Pleasanton, CA
    11,743
    Correct but what I was refering to was other pump models/manufactures.
    Mark
    Which HP SuperPump do you think would be the best choice for the poster?
    Support the site
    mas985's Avatar
    Pleasanton, CA
    11,743
    Quote Originally Posted by abbysdad
    Sounds more like a done deal. Certainly a smaller pump might be possible but my concerns would be for the backwash requirements of the filter if any and if there would be any plans in the future for solar panels on a roof.
    Mark
    Jun 2011
    Michigan
    41
    Also, does this thing come with an on off switch? I haven't gotten it yet and I am going to have an electrician wire it, but if it doesn't have an on off switch, I might buy a timer and have him do that also.
    22,553
    I'd opt for the timer anyway. it's so much easier to have it start and stop automatically.
    Jun 2011
    Michigan
    41
    would something like the intermetic T101R3 be sufficient? I am planning on having the pump wired to 110v.
    22,553
    That would be a good one!
    Apr 2011
    Toledo, OH
    71
    Can you use 2" pipe on the Metric or do you have to use 1.5"?
    The man on top of the mountain didn't fall there.
    24' x 52" Intex ultra frame pool (12,400 gallons) with seperate Intex 2500gph pump and SWG and 2 Intex magnetic pool lights.
    Looking to upgrade to 27-30' semi inground install
    Jun 2011
    Michigan
    41
    I think the fittings are 1.5".
