Thread: pool storage for rafts and other stuff
    May 2009
    Trenton NJ
    497
    I have a shed we usually store our pool stuff but it gets the floor wet and some times we have had problems with rafts etc getting punctured. So can anyone recommend a economical way to store things just durning summer time so we have easy access to them and no risk of damage to inflatables?
    Don't need anything real big but needs to house at least 2 rafts that are around 6'long.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Re: pool storage for rafts and other stuff
    PVC pipe to the rescue. You can use 3/4" or to make it more sturdy 1".
    On the two long sides (since rafts are 6' the frame can be 5' long. Start with a 90* elbow, piece of pipe 10", the a T pointing up. Out of the through side of the T a 4' piece of pipe, another T pointing up, another 10" piece of pipe and a 90* elbow. Make 2 of these.
    Cut 6 pieces of pipe 33" long. (you can get 3 from on 10' piece of pipe and have a piece left for the short pieces) These will be stuck in the T pointed up.
    Cut 4 pieces of pipe 5" long. Insert them in the through sides of another T. Now connect them to the 90* elbows with the open end pointing up.
    Take your other 2 pieces (of the 6 you cut) and stick them in the Ts. This will separate the two rafts as they are standing up.
    Shopping list.
    3- 10' pieces of pipe preferrably 1"
    6- Ts
    4- 90* elbows
    Cuts.
    6 - 33" long will leave you 2 pieces 21" long.
    4 - cut the 21" pieces in half. These
    2 - 4' long
    4 - 5" long
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Like AquaDoctorLLC said.
    PVC is very handy, and cheap.
    Here are some things I found on Google just browsing.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
