Results 1 to 16 of 16
Thread: Algae Problem
    May 2008
    Hockessin, Delaware
    48
    Algae Problem
    OK so i am at the end of rope with this pool this year. First of all my readings.
    5.5 - FC
    0 - CC
    70 - TA
    PH - 7.6
    CH - 270
    CYA - 70
    Pool is constant sunlight from sunrise to sunset. Water temerature yesterday peaked at 86 degrees.
    Now the problem is the stains that you will see in the following pictures all the way around my pool that i believe to be algae. I brush the pool every single day but the algae continues to grow. Water is sparkling clear. I have a new Jandy Aquapure 1400 SWG set at 85%, pump runs 14 hours per day, and i keep two 3" trichlor tabs in skimmer basket at all times, using polyquat 60. Seams to use a ton of chlorine. I have tried and checked everything. Shocking constantly, almost daily. Are the 2 different types of chlorine counteracting each other ?
    http://i83.photobucket.com/albums/j313/ ... olPic3.jpg
    21 X 42 freeform gunite pool w/ spa
    white plaster finish
    Jandy VS ProFlow Pump
    3 returns, 2 skimmers
    pentair DE filter
    Aquapure 1400 SWG
    Raypac 399,000 BTU Heater
    Zodiac Nature 2 Pool sanitizer (haven't used yet)
    Re: Algae Problem
    That looks like it might be mustard algae, which is rather difficult to get rid of. There is a Pool School article, here, on fighting mustard algae.
    May 2008
    Hockessin, Delaware
    48
    Re: Algae Problem
    Sorry for all of the questions. I am going to try and do this major shock treatment to see if this is mustard algae. It does not brush off when i try to brush it. According to the chart i will need to get my shock level up to about 40 ? Has anyone ever tried the non chlorine shock ? I have never used the clorox bleach before but cant stand the smell. Do you smell it when adding to the pool at such a high level ?
    pentair DE filter
    Aquapure 1400 SWG
    Aug 2010
    Dallas, TX
    4,052
    Re: Algae Problem
    First, when you brush those stains, do they make a yellow cloud?
    This video is good at showing what it looks like. DO NOT FOLLOW THEIR DIRECTIONS ON CHEMICALS!!
    http://www.youtube.com/watch?v=xsY7hyuGxys
    EDIT: I see you say it does not brush off. The video above will still be helpful for you to know what MA looks like.
    Next, with your CYA level, I strongly suggest you stick with Clorox.
    To answer your question about smell. When you smell a bleach-like smell in a pool, that's not from free chlorine. That is chloramines, from the chlorine clearing out an organic problem. When your pool is sparkly clean, you will NOT smell a bleach-like scent from your pool.
    Please realize the chlorine in Clorox is exactly the same chemical as any chlorine shock, tablets, or powder. It's not like the pool stores came up with a new chlorine element for the periodic chart.
    Now, since your stain is not MA, do you have any trichlor tablets? Try scrubbing the stain with one of the tablets (wear a glove) and see if that removes the stain. That will help to determine if it is organic or not.
    May 2008
    Hockessin, Delaware
    48
    Re: Algae Problem
    can anyone else look at the stains in the above picture. They are definitely spreading and now seem to be appearing on the bottom of the pool not just the walls. When you brush them a little bit of a cloudiness occurs but the stain does not go away at all.
    pentair DE filter
    Aquapure 1400 SWG
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Algae Problem
    Sure looks like algae.
    What test kit are you using? When do you test?
    With CYA at 70, minimum CL is 5ppm, target is 10, and shock is 20. If it is mustard, then 39ppm is indicated.
    Are you aware that shocking is a process rather than a product? If you shock and then do nothing, you are always going to be backtracking because you never kill all the algae. It re-grows.
    Have you read the information about the shocking process in pool school?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Aug 2010
    Dallas, TX
    4,052
    Re: Algae Problem
    I have never had black algae, but maybe someone who has seen it can say whether it is or not?
    Try the "scrubbing them with a puck" test on it, it will help us diagnose the issue.
    30,421
    Re: Algae Problem
    Well, the stains are surely organic. Confirm that by taking one of those pucks and holding it against the stain for a couple of minutes. If the stain is removed or gets lighter, it is organic.
    Report back the results of that test and we'll go from there.
    As an aside, completely remove the pucks....they are doing little or nothing to help you.
    May 2008
    Hockessin, Delaware
    48
    Re: Algae Problem
    SO i took one of the pucks and rubbed it on the some of the stains and they seemed to get a little lighter but did not go away. is this another sign that i need to shock the pool ?
    pentair DE filter
    Aquapure 1400 SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Algae Problem
    Quote Originally Posted by GZelano
    Yep!
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Algae Problem
    If it is mustard algae (looks like it to me) and will not brush off, are you using an algae brush?
    May 2008
    Hockessin, Delaware
    48
    Re: Algae Problem
    i am using a standard pool brush. What is an algae brush ?
    pentair DE filter
    Aquapure 1400 SWG
    May 2008
    Hockessin, Delaware
    48
    Re: Algae Problem
    So i googled algae brushes and the stainless steel bristled ones look like they would work the best. are they O.K. to use on the plaster finish of a pool ?
    pentair DE filter
    Aquapure 1400 SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Algae Problem
    That's what they are made for.
    May 2008
    Hockessin, Delaware
    48
    Re: Algae Problem
    SO once again thank you to this forum. I received my stainless brush today and boy what a difference. The water now clouds when i brush the stains and they got lighter. So i started the shock process. cya is 60 and FC is 30 using liquid chlorine. Brushed the entire pool and it is very cloudy, YEAH !!!! I cant believe i brushed the pool every stinking day with a normal pool brush and nothing happened. My question now is approximately how long will it take before the pool is at safe levels for my kids to be able to swim in ?
    pentair DE filter
    Aquapure 1400 SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Algae Problem
    If you indeed have mustard algae, (which it looked like it to me), you should follow the direction for Mustard Algae shocking in Pool School. Don't forget the light niches, ladders, and pool equipment. Then the swim suits and everything that had contact with the water.........
    Complete directions in Pool School.pool-school/mustard_algae
    Make sure you do the entire episode of shocking, or it will just come right back and bite....
    Best to just forget about swimming until the shock process is completed by having met all three criteria to be done shocking, and then the FC will be allowed to drop. Once it then drops below normal shock level for your CYA (below 24) swimming will be okay.
    Congrats on getting the s/s brush! There is nothing like having the correct tool to do a job!
