Results 1 to 17 of 17
Thread: Having pool party.....questions!!
    Apr 2010
    Central Illinois
    205
    Hi,
    we are having our first pool party in a few hours....Right now FC is 5. We are expecting approx. 20 kids age 14. How much bleach should I add to last the whole party? Party is from 2 pm to 7 pm. (if that matters)
    Thanks in advance!!!!!
    15x30x54 AquaLeader Sentinelle AGP
    2 HP 2 Speed Hayward SwimPro Voyager Pump
    Hayward SwimPro Voyager 150 sq. ft. Filter
    Hayward H series millivolt 150 btu Heater
    TF-100
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Having pool party.....questions!!
    If you normally hold the pool at 5.....adding another 2-3 ppm should be good. Then readjust FC level when the party is over. See the poolcalculator in pool school for your volume and how much to add. Half gallon or so is my guess. Can you post a set of test numbers?
    Apr 2010
    Central Illinois
    205
    Results on 7/04 were
    FC 3.5
    CC 0
    pH 7.5
    TA 60
    CYA 40-50
    I plan on running all tests after party tonight or tomorrow.
    Would it be okay to get FC up to around 10-12?
    TF-100
    You can swim at under shock level but no need to go that high, IMO. Just to top of normal range, or maybe 1 - 2 higher. If you are worried, test mid-party and pull kids out for popsicles while you add and circulate bleach.
    Butterfly's Avatar
    South Carolina
    10,045
    Your shock level is somewhere between 15 & 20, so your 11 or 12 is fine.
    Definitely check pH and FC after the party/tonight!
    Anona's comment to check mid-party is a great idea
    You're done SLAMing when:
    Apr 2010
    Central Illinois
    205
    thanks everyone!! One more question though, Do I have to shock after party?
    TF-100
    Apr 2010
    East Texas
    9,609
    Only shock is your testing tells you to. Now I want a popsicle dangit!
    Maybe. I'll bet pool is dull at best. I'd raise to shock level overnight, let the pool have a day to discharge CCs, then decide.
    Maybe then do OCLT the next night, if loss noted, do a proper shock. Call me lazy.
    Apr 2010
    Central Illinois
    205
    Thanks!!
    TF-100
    Butterfly's Avatar
    South Carolina
    10,045
    Oh my goodess - 20 teenagers is a lot lot lot! I'd shock tonight, too.
    Jul 2011
    Rockwall, TX
    8
    Just interested, I'm having a similar party this weekend, except the kids are adults and the popsicles are beer. How did your levels hold up? What did you do?
    Taylor FAS DPD test kit. 30k gal salt in-ground plaster pool. CircuPool RJ45. Cartridge Filter.
    Jul 2010
    Mickleton, NJ
    229
    Quote Originally Posted by Formula27
    I acutally had kids and adults recently. It was a party that went from 2:00pm until 1:00 am. People literally swam the entire time. I bumped my FC up from my normal 8 to 10 before the party. The morning after the party I backwashed (we were almost due before the party) and dropped the auto cleaner in the pool. My FC was at 4, and pool was cloudy. I bumped it back to 10 and pool was nice and clear in a few hours.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Jul 2011
    Rockwall, TX
    8
    Great! I hope mine goes well. My FC is at 4.5 so I better get to moving.
    If they're swimming and drinking the entire time... make sure they leave the pool pretty often!
    -Tom
    17,000 gal plaster with spa. Pentair Clean & Clear cartridge filters. Jandy systems with Aqualink RS and Polaris 360.
    Pool Store free since May 2011!
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,059
    Just bump the chlorine up. Last weekend we had a party of about 48 people and We had 25+ people in our pool all at one time, kids and adults. Our party lasted 10 hours. The next day the pool was a bit cloudy however my chlorine level was a bit low. Ran the filter and in a couple of hours the pool was clear and sparkly
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    not to be a party pooper, but I would keep glass away from my beautiful pool.
    24' AG Doughboy w/ 5'8 dish bottom, CWII DE Filter, 1.5 hayward 2 speed pump, Aquatrol SWG.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    We had a small pool party today. Actually, my wife did more than me; I was at a train show with my club. But I knew it was going to happen, so I vacuumed last night and gave it 2 extra ppm FC. Before I took off this morning, I doublechecked pH and FC, and everything was perfect.
    Came home to find a couple of adults out of the pool, a couple in the pool, and 3 kids, including a 2 year old in swim diapers and a 4 year old. They liked the hot tub, it had that nice shelf to run around on.
    After they left, the water looked a little cloudy. So I dumped half a gallon in and brushed things around a little. It's already looking better.
