Results 1 to 9 of 9
Thread: Cartridge Filter Too Coarse
    Nov 2010
    Flippin, AR
    11
    My skimmers remove a layer of dust from the top of the pool, and a dirt accumulates under my the return jets. I believe that the Cartridge Filter used in my Pentair Clean & Clear CC200 is too coarse and I'd like to get a better filter. I have more than enough flow to tolerate a bit more restriction. I have tried two different filters, the original that came from Pentair and an aftermarket, both rated at 30 microns. I'd really like to filter down to 10 microns or so. Does anyone know of a replacement filter that would meet my needs?
    15,000 Gallon in-ground Fiberglass (Viking Lake Shore)
    Cartridge Filter (Pentair Clean & Clear CC200)
    2HP Pump (Hayward SP2615X20 Super Pump)
    SWG (Pentair IC40)
    Heat Pump (Jandy EE-2500T)
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Cartridge Filter Too Coarse
    I was considering the same thing. My current sand filter lets a lot of small stuff through and I would like a more efficient filter. Been reading up on the DE filters and they seem like they would do the job. The only problem I have is what to do with the back wash. Here's a link to the Hayward brand of DE's: http://www.hayward-pool.com/ctg/In-Grou ... 5516_I.htm
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    If you have visible dirt accumulating below your return jets then something is wrong. A cartridge filter will filter out anything you can actually see if it is working correctly. The most likely possibility is that the cartridge fabric is torn, but there are some parts inside the filter that could be broken and cause the same issue.
    stev32k, try adding a little DE to your sand filter, as described in Pool School. That should improve things noticably.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I have DE in the filter now and have been adding it off and on for the past two days. It has made a noticeable difference in water clarity. The only problem is I need to back wash about every two or three hours and that is with only one cup of DE. Maybe the back wash frequency will decrease as the water continues to clear up - at least I hope it will.
    I still like the idea of a filter that will remove particles down to about 2 microns. Just wish I could come up with a good solution to the problem of how to handle DE in the back wash water. I''m not too keen on just letting it collect on the ground, but I don't know what else to do that is in economic reason.
    I have just finished a "filter cycle" with the addition of Fiber Clear to my Intex filter pump, while shocking away some algae.
    Seems to have made the filter a bit tighter, it was loaded up quite nicely after a week. I'm happy enough with the purchase, and it wasnt terribly expensive.
    Dec 2010
    San Diego, CA
    1,137
    Quote Originally Posted by stev32k
    You could get a DE separation tank for the backflush - Let's you save the backflush water too.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Apr 2011
    Toledo, OH
    71
    Quote Originally Posted by JohnAJohnson
    I noticed this same 30 micron rating on Pentair cartidge filters and am confused. In reading the Pool School here and on other websites that have their versions of it, all seem to say that cartidge filters filter in the 10-15 micron range. Why is Pentair saying 30?
    The man on top of the mountain didn't fall there.
    24' x 52" Intex ultra frame pool (12,400 gallons) with seperate Intex 2500gph pump and SWG and 2 Intex magnetic pool lights.
    Looking to upgrade to 27-30' semi inground install
    Nov 2010
    Flippin, AR
    11
    Thanks all. Good suggestions. If I can't find a tear or anthing wrong with my filter cartridges, I might try adding a Super Slime Bag (http://www.cleanerpools.net/slimebag.php). Anyone have any experience with these?
    SWG (Pentair IC40)
    The bags filter very very well. Some people find them to be in the way and/or unsightly, and cleaning them can be annoying. Also, they can let through some very fine dust when bumped.
