Results 1 to 11 of 11
Thread: filter question
    Jul 2011
    Glace Bay, Cape Breton, NS, Canada
    4
    filter question
    Hi all!
    I'm helping my daughter (her fiancee is working away) who are first time pool owners. The pool is an inground pool 16x 32. The filter is a Jacuzzi Laser 225.
    She tried to get the local pool people around here to open it but gave up when they didn't return. So her and I are trying to open the pool for the first time.
    So far, we have removed the winter cover. The water was BLACK. We scooped out as much leaves as we could (remember can't see).
    Poured jugs of chlorine in (I think 5 maybe). The water is now green. Went to pool place bought "shock". Told to use 2kg (that was yesterday) water still green. Added algaecide (sorry if spelled wrong) as per directions given at pool place. If water is still green we were told to repeat the process.
    Any suggestions to help us would be greatly appreciated.
    Also, it says to backwash the filter if the gauge is above normal; however, it doesn't say what is normal. Would anyone have an idea what range we would be aiming for????
    Dolorosa & daugher
    30,413
    Re: filter question
    If it is your daughter's pool, the best help you could give her is for her to come on the forum and learn first-hand how to manage her pool. If she does not learn on her own, the pool will quickly return to a black swamp.
    Jul 2011
    4
    Re: filter question
    Oh, she will...it is just that she was busy and I found this forum so I started for her. She will read it for sure!!!!!!
    Jul 2011
    4
    Re: filter question
    Anyone?????
    Re: filter question
    There is a really good article here. turning-your-green-swamp-back-into-a-sparkling-oasis-t4147.html
    Have read of this and come back for any advise.
    16,000 Gallon IG SWG Plaster Pool
    Jandy Cartridge Filter
    Integrated hottub with gas heater
    Pump Size 1 hp
    Gilbert AZ
    Jul 2011
    Richardson, TX
    2
    Re: filter question
    It really depends on the filter and system downstream. If you haven't already backwashed it, then do that. When you start it back in the filter mode make a note of the pressure on the gauge, this will be the "normal" pressure. Backwash when filter pressure rises 10psi over the starting pressure.
    Mike
    28000 gal gunite/plaster IG with spa. Hayward S310s sand filter 98GPM, 2HP pump
    May 2011
    Clearwater, FL.
    446
    Re: filter question
    double post
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    May 2011
    Clearwater, FL.
    446
    Re: filter question
    If your going to do this yourself... just like me I'm a mechanic, I have to have all of the proper tools in my toolbox to do my job correctly.
    My biggest advice is go online here and buy a TF-100XL testing kit, without this proper tool your really making it too hard to do and you will most likely give up.
    http://tftestkits.net/splash-page.html
    My TF-100XL kit is the best tool in my toolbox, not only has fixed my pool, it now keeps my pool a Trouble Free Pool!
    Chuck
    TF-100 test kit
    Apr 2009
    Burlington, ON, Canada
    344
    Re: filter question
    He's in Canada and won't be able to have that kit shipped up there.
    Try www.piscines-apollo.com for a Taylor K2006 kit.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Jul 2011
    4
    Re: filter question
    What is "CYA" level and "FC"???? Thanks for the help we will take all we can
    May 2011
    Clearwater, FL.
    446
    Re: filter question
    Quote Originally Posted by Dolorosa
    Go to the Pool School link at the top of the page.
    http://www.troublefreepool.com/pool-school/
    Go to ABCs of Pool Water Chemistry
    http://www.troublefreepool.com/pool-...ater_chemistry
    Read read and read! :P
    Chuck
    TF-100 test kit
