Results 1 to 8 of 8
Thread: Added 36 lbs CH up, zeroed out the Chlorine
    Added 36 lbs CH up. zeroed out the Chlorine. SWG system. Kicked up output also had to raise CYA from 30 ppm. Added 1 gal for a 20000 gal pool.
    Has this happened to anyone else, what is the deal.
    Seamus
    Slainte
    20,000 gal IG Gunite Pool - 1/2hp Hayward North-star Pump SP4005
    Hayward Swimclear Filter C4030 Sta-Rite SR400NA Max-E-Therm Heater, 400-BTU
    Jandy APURE35 AquaPure 35K Gallon EI Saltwater Chlorinator 120/240V - Nitro Wall Climber/scrubber
    30,421
    Re: Raised calcium hardness and free chloring went to zero
    How are you both testing?
    This was the test after CH up added
    Before CYA up added
    FC=0
    pH=7.8
    TA=80
    CH=300
    CYA=30
    Temp=80
    Using Leslie's Total Poolcare DPD Test Kit - Taylor product
    I did not test TC
    Seamus
    Slainte
    30,421
    The CH test in the K-2005 is a good test....I was concerned you were using strips. I cannot explain the loss of FC as they are virtually unrelated. Is it possible your FC slipped to zero naturally prior to that test and you just hadn't noticed it?
    In the instructions for Jandy AquaPure it says to turn SWG unit off when adding chemicals. Any chance that calcium upset the SWG?
    Re: Added 36 lbs CH up, zeroed out the Chlorine
    Calcium chloride won't have any effect on FC. But there is some chance that there was some organic contamination in your calcium chloride that could have used up chlorine.
    anonapersona, adding calcium shouldn't have had any direct effect on the SWG. It is possible for the CH level to get too high, and for that to cause scaling, but Seamus's test results don't suggest any problem there and it would take at least several days to have any effect even if there was a problem.
    Thanks Jason, I'm sill learning. Can we rest my post count to reflect my still-a-novice status?
    Hey, don't fret. I'm over 20,000 posts and I still make mistakes sometimes! Making mistakes is a natural part of the learning process, at all levels of experience.
