I could use some help here... I, too had this K1 solder problem a while back and found the solution on this forum. A little glob of solder on the back of the board and problem was solved. Fast forward a few years - T-15 cell was replaced with generic replacement from Compupool and worked fine for a long time. Now, I'm getting the high salt/amps message. The salt level in the pool is actually quite low, around 1900-2600ppm. I've been meaning to add salt, but now that I've discovered this problem, I'm not sure what to do. I took the board off and my little glob of solder from before is still intact. Just to be sure, I globbed a little more on there - but it hasn't solved the problem.
Low salt and little glob of solder is good. What else could cause this error...?
Please help!!
JT
(this is a goldline aqua-logic ps-4, I think...)
Thanks!
