Thread: Cloudy Water
    Cloudy Water
    Shocked after chlorine went low and turned cloudy. So I shocked again.
    10000 Gal above ground - vinyl liner, PH OK and chlorine very high?
    Also put in algey stuff as required. I run pump 24 hrs always. Sand = I also backwashed and so on Pool is 23 years old.
    This only happened 2 times in 20 years. Ideas please.
    24' AGP sandstone,12,000 gal , cricupool rj30 SWG,fas-dpd test kit. BBB
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Cloudy Water
    Quote Originally Posted by glbpab1225
    SHOCKED AFTER CLORINE WENT LOW AND TURNED CLOUDY. SO I SHOCKED AGAIN , 10000 GAL ABOVE GROUND - VINAL LINER, PH OK AND CHLORINE VERY HIGH? ALSO PUT IN ALGEY STUFF AS REQIRED. I RUN PUMP 24 HRS ALLWAYS. SAND = I ALSO BACWASHED AND SO ON POOL IS 23 YEARS OLD. THIS ONLY HAPPENED 2 TIMES IN 20 YEARS . IDEAS PLEAE
    Welcome to the forum
    Please post a full set of test results.
    See Pool School (white button top right).
    Shocking a pool is a process and not a one-time event!
    You're done SLAMing when:
