Results 1 to 20 of 20
Thread: Intex 2650 Sand Filter Base Dimensions.....building base
    Jul 2011
    NJ
    67
    I've ordered the Intex 2650 sand filter and want to get a head start on my platform for it to sit on.
    Can someone please tell me the base dimensions.
    Thanks!
    Intex 15x36 Easy Set (2,800 g.)
    Intex 16" 2650 gph sand filter/pump combo & SWCG
    Intex 800 gph filter just for the surface skimmer
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    Re: Intex 2650 Sand Filter Base Dimensions.....building base
    I'm not sure about the size difference but my 1600 sandfilter from intex in on a on two 1 1/2 ft square pavers.
    5,061 Gallon 16' x 48" Intex Metal Frame Pool
    14" Intex 55Ib Sand Filter and Pump.
    _______________________________________
    Location: Columbus, GA Where the Heat and the humidity are* :)
    Jul 2011
    NJ
    67
    carterj92-
    Around how much space is left around the edges?
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    here is my 2100gph with the SWG. mine is 4x3.......[attachment=1:204chex4]19607.jpg[/attachment:204chex4][attachment=0:204chex4]60721.jpg[/attachment:204chex4]
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    Jul 2011
    NJ
    67
    Perfect...that's exactly what I needed to see, jsf0656!
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    hoped that helped!
    Greg78's Avatar
    Jun 2011
    N Ft Myers, FL
    13
    George_ did you get your Sand Filter System yet?... Got mine earlier today and had it hooked up in about 30 minutes. This thing is great, really moves the water. Going to buy an outdoor timer and run it a couple of hours in the night and then a couple of hours during the day.
    Intex Ultra Frame 16' X 48" (5,000 Gallons)
    Intex Sand Filter System (2650 GPH)
    Taylor K-6000
    BBB
    Jul 2011
    NJ
    67
    Yes I did. Got it yesterday morning and my neighbor hooked me up with a 36x36 A/C condensor pad to put it on!
    I ran it for 5 hours yesterday and 10 hours today and my water is **** close to crystal clear. It had been extremely cloudy (really needed to vacuum, but couldn't with the other filter) and the 637R pump running 24/7 for ever could never do what this filter did in hours I'm very happy.
    I haven't decided yet how I want to run it, but defintely need to have it going early morning so the skimmer can get all of the bugs that came to the pool party, but never left.
    Hey Greg...
    maybe you can answer this one. On Intex's site they list this model filter as 2100 GPH (even though the box says 2650.) But on Amazon they list another 16" sand filter which in it's specs says the pump is upgraded to 2650 vs. 2100 of the older model. And that one sells for $50 more. You posted some info in my other thread so maybe you know what the deal is with that. Is there an "older" model and why the 2 price differences?
    Jun 2011
    Cape Girardeau, Mo
    125
    I couldn't figure out why the $50.00 more either and they have the same model # to. This is the best thing i ever did though my water is crystal clear i have had it for 3 weeks i fought with cloudy water all last year and the beginning of this year with the 637r running 24/7 so far i am running this one 8hrs and could probably only run it 6 hrs overall i am well pleased everyone with an Intex pool should invest in one.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    Greg78's Avatar
    Jun 2011
    N Ft Myers, FL
    13
    Quote Originally Posted by George_
    Hey Greg...
    I'm not 100% sure. Everything I've seen tells me they are the same pump. To me it seems Intex decided to advertise the Max output spec, change their packaging and charge more for it.
    Taylor K-6000
    BBB
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Here is a picture on my system sitting on a 5' x 8' wooden deck.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Jul 2011
    NJ
    67
    Thanks, Mark.
    Believe me...I may be new around here, but I've seen your setup
    Now let me ask you....what is with the hose bib between the pump and filter?
    crookm11's Avatar
    Jun 2010
    422
    One reason I installed the hose spigot was to help with the testing of the plumbing joints for leaks. After I got everything plumbed I closed the ball valves at the skimmer and pool fittings and hooked up a water hose and turn the water on. Basically I used it to provide pressure in the system to check for leaks.
    The other reason for the spigot was to help with the priming of the whole system. I just open up the spigot a few seconds at the initial startup for the pump to relieve the air pressure and then close it. If you look at the pressure gauge on the filter you will see the green "Safe" section is only to about 5 psi. The Intex hoses that come with this filter/pump is very restrictive and doesn't allow a whole lot of water movement through the system. Once you take the hoses off and add free flowing PVC into the system the flow rate and pressure will rise dramatically and provide a much better water filtration system overall. The base PSI reading on my system went from about 6 PSI with the hoses to about 11 PSI when I went to PVC.
    Mark Crook
    Jul 2011
    NJ
    67
    Quote Originally Posted by crookm11
    If I recall, my gauge shows green until 11 or so and is sitting at 8-9 after a couple days. If that pressure goes up when hard-plumbed then that would put me clearly into the yellow area. Being the noob that I am, isn't that not where you want to be running your filter?
    crookm11's Avatar
    Jun 2010
    422
    Intex may have changed the pressure gauge for the more recent model. Reguardless of what the gauge says the filter has a working pressure of 50 PSI. With that being said as long as you have the correct amount of sand in the filter you will be fine at what ever pressure you have. All pumping systems are different. even system plumbed the same will have different reading on the gauge.
    I will take a picture of my pressure gauge when I get home to show you the difference my system changed in pressure going from hoses to PVC.
    Mark Crook
    Jul 2011
    NJ
    67
    I found some interesting info on the discussion of the 16" pump ratings....
    After ordering my filter I went around the Internet searching for the manual in .pdf form and found it (wasn't easy.) Last night I decided to compare the 2 and noticed they were different; not much, but different. What is interesting is the .pdf I got had the number 127 in the upper-right corner along with a date of 9/2009 in the header (the Amazon listing everyone here bought says 9/2009.) Under specs the pump is rated at a max of 2100GPH. Now the printed manual that came with my new filter has the number 127-1 in the upper-right corner and the specs list the pump with a max of 2650GPH.
    So, maybe there really is a newer model and we got it?!?!
    ...Or they changed the way they rated the pump???
    crookm11's Avatar
    Jun 2010
    422
    I haven't looked at mine yet but I think the best place to look for the rateings would be on the pump itself. Manuals can be changed at anytime. Marketing can be tricky also when a company wants to sell their products. All I know is my pump works great.
    Mark Crook
    Jul 2011
    NJ
    67
    Good call. I'll check it during lunch.
    edit: there were no rate listings on the pump.
    folks, am new to the site but checking your pools out. They look awesome! I like the hard plumbing. Was wondering about your pool wall skimmer. Am assuming it's custom. how low does you pool level need to be? How under the seam does it need to be? would like to some details on how to do and which one works best.
    pool light looks good too.
    18x36 IG Steel Wall Vinyl 25K gallon 3.5-8ft, Hayward 4820 DE Filter, Hayward 1HP Super Pump, Hayward 250K BTU NG heater, Zodiac Baracuda MX8 Cleaner, 4 jets (steps/deep), 1 return
    30 mins North of Pittsburgh Pennsylvania
  20. Back To Top    #20
    May 2012
    charlotte n.c
    28
    can anyone tell me the over all dimensions of the unit out of the box? i have a outdoor box i would like to put this in but dont think it wil fit. thanks
    INTEX 14' X 4'
    1000 GPH PUMP
    SWG
    taylor K-2006 K-1766
    SKOOBA VAC
