Thread: Pump Selection
    georgewever's Avatar
    Jul 2011
    Joplin, MO
    8
    Pump Selection
    I am new to the site and the pump that was installed on my pool apparently was for above ground pools. I cant read anything on the pump any longer and need to replace it. I have a 18k fiberglass saltwater pool. Its 8' deep and has 1 1/2" pipe. I would like to set the timer to run the pump for 4hrs a night. I am not sure what HP motor i would need to make sure i get the proper circulation of water for this scenario. I am thinking 3/4HP is whats in there now and that's probably going to be sufficient but again not sure. Thanks for any help...
    Also here is the pump i am looking at and one of the features that appeal to me.
    Hayward ¾ HP SUPER PUMP SP2605X7
    Self-priming (suction life up to 8’ above water level) although its a little over 8' from bottom of pool to my pump its only about 2' from top of water...
    24k in-ground Fiberglass Pool, Easy Touch Automated Timer, IntelliChlor Salt Generator, Sand Filter, 1.5HP pump, Aqua Cover, Diving Board, Slide
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Pump Selection
    The super pump should be fine. You may also want to consider a 2 speed pump, either 3/4 or 1 hp. You can run it on low for circulation and on high for vacuuming.
    Love TFP? Become a
    TFP Supporter!
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Pump Selection
    If you go one size larger with the SP2607X102S, you can get a two speed which is a good way to save energy/money. It doesn't come in a 3/4 version but the 1 HP version is actually an uprated pump so the performance is similar to a 3/4 HP full rated pump.
    Mark
    Jul 2011
    Joplin, MO
    8
    Re: Pump Selection
    Thanks for the info I was considering the two speed pump however I don't know how to set up the easy touch for it so i would have to have someone come out and wire/set up the system for it. Since i only run the pump at night {except when we swim or vacuum} to keep the water cooler i figured a one speed was sufficient. During the day with the cover closed if i run the pump it heats the water up quite a bit and since i don't have a fenced yard i don't have much of a choice but to keep the cover closed. So i am thinking 3/4 HP running for 4-6 hrs every nite should be perfect?
    BTW i noticed you were from Pleasanton, CA I was born in Walnut Creek Kaiser and grew up in Antioch... Big sharks fan had full season tix before we moved out here... about to put up logo for thumbnail...
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Pump Selection
    Did you check the manual? It should instruct you how to connect a two speed pump. Here is a list of manuals at Pentair: Pentair Manuals
    Mark
