Page 1 of 8 1234 ... LastLast
Results 1 to 20 of 156
Thread: Droid App - Wrote my Own
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Hi All,
    Based upon the rules, I believe this post is legal.
    guidelines-for-posts-by-people-who-are-in-the-industry-t15260.html
    The few existing pool maintenence Android apps did not do what I was looking for.
    I wanted one that supported the BBB philosphy as well as had functionality similiar to Jasons fantastic PoolCalculator.
    Since none existed, I wrote my own.
    This is BETA software. There is much more work to be done to complete it.
    I am hoping there are some people out there who would be willing to give it a try and provide me some feedback.,
    The app is called Simple Pool and can be downloaded from the Android Marketplace.
    http://market.android.com/details?id=ne ... SimplePool
    As this is beta software, some functionality may be incomplete or be buggy.
    Additionaly, you sould know that this software will expire 8/1/2011.
    If you are willing to give it a try and provide feedback, It would be very much appreciated.
    Please address any comments regarding support, suggestions, or bug reports directly to me (and not on this forum.)
    I hope some of you find it useful.
    Again, this is beta software, it is not complete, use at your own risk.
    CURRENT SUGGESTIONS AND STATUS
    * Fix SWG advice calc = Complete
    * Complete additional info for remaining levels = Complete
    * Complete the effective change for all adjustment levels = Complete
    * Calc CSI/LSI index = Complete
    * Add ability to set own level ranges = Complete
    * Assume last measurement is good = Complete
    ######## New in Beta 1.9.3 (8/12/2011) Release ########
    * Add effects of adjustments to graphs = Complete
    * Remember what chemical/vol, was used last (and default the adjustment screen to that) = Complete
    * Show measurements in some sort of table. = Complete
    * When viewing a records list, can you add a confirmation for record delete. = Complete
    * On the graph screen add a "back" button to bring you back to the "Charting Options" screen = Complete
    * Table of results. = Complete
    * Add ability to configure multiple pools - = Complete
    * Backup/Sync data = Complete
    ######## Open Items ###########
    * Add metric conversion - Open
    * Email pool test results - Open
    * Create button to show shock levels - Open
    * When editing/viewing records, can you add "Previous" & "Next" buttons to cycle through the records
    * On the graph screen, can you make it so when I tap a data point it opens that record?
    * Add Bromine and a saitization method.
    * Log pump presure and flow rate
    * Incorporate use of Sodium Thiosulfate
    * Inventory feature (chems, etc)
    * Pool cost collector.
    * Show suggestions in additional units (not only oz)
    Sincerely,
    -Ken-
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    Re: Droid App - Wrote my Own
    Ken, I just downloaded your app to my 1st gen Motorola Droid. Thanks for making it available using bbb.
    I'll give feedback
    15x32 Lazy L Inground / Concrete - 20,000 US Gal 1979 build
    1.0Hp Maxiglass/ Sand Filter, 7th season with Pool
    Painted cement finish repainted 2011
    400,000 btu Pentair Master Temp NG
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Thanks MJCP,
    Set the defaults on the main screen and it should be ready to use.
    -Ken-
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Just Downloaded here also... will keep you posted...
    I have my salt level set at 3200 and I entered that as my measured and it is giving me a salt level too high message... ????
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Hi dremin2flyhi,
    As the range for salt levels are SWG vendor specific, you must first configure the vendor reccomended ranges in the the "Defaults" on the main screen.
    Next, you must measure your water and record your levels.... then, the "Advice" should give you accurate suggestions.
    The 'Advice" will always report based on the last levels recorded.
    What was you salt range set at and what did you measure?
    -Ken-
    Jun 2010
    Darlington, SC
    121
    Ken,
    in the Defaults I set-- min to 3200 max to 3500
    Measure I put in 3200 -- then under the suggestions /advice screen it is showing the Rec Level as correct from 3200 to 3500
    then in your level I have 3200 that was entered from the measure screen..
    Which SDK/ ADK version are you using to build this app ??? I have played around with some --but haven't become proficient yet...
    I do know Open PCS and other Logic controller software.
    Dolphin E10
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    dremin2flyhi,
    Found the problem,
    I just uploaded a new version, it should show up in about 15min.
    Adroid market should tell you an upgrade is available.
    I am using Eclipse on a windows XP PC.
    -Ken-
    Jun 2010
    Darlington, SC
    121
    just got it--that took care of the issue for that
    Dolphin E10
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Thanks dremin2flyhi,
    That is/was exactly the kind of feedback I was hoping for.
    -Ken-
    Jun 2010
    Darlington, SC
    121
    Ken,
    Very welcome.. glad to help out.. I know writing thousands of lines of code is no fun.. Some days I sit at my desk running debug mode for hours on end on some things I do. Durn semi colons and hyphens and global assignments kill me...
    Dolphin E10
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    dremin2flyhi,
    Thanks! I have been a developer for 17 years. Ya know what I just realized? The importance of good copy/ paste skills. The code is similar for all the different chem levels, so I copied it... my mistake was that I did not update a variable. I left it as the calcium hardness range instead of the salt range.
    Thanks again!
    -Ken-
    Jun 2010
    Darlington, SC
    121
    Ken,
    I know the Copy/paste routine all to well--it will bite ya in the butt
    Dolphin E10
    Jul 2011
    Boardman Ohio
    16
    I will try it as well next Friday when I get my new phone....right now using a BB Torch and no apps I ever want are written for it
    I have a Vinyl IG pool (21,200 gallons) with a sand filter.
    South Central NJ
    3,192
    A minor nit:
    I told it my FC was 3 and CC was .5 and in the advice section, it said my FC was 2.5 and CC .5 Seems to relabel the FC as TC.
    I don't think it should suggest raising CH if the pool type is liner.
    A huge thank you for the ap!!!!!!!
    Scott
    Owner of - PoolGuyNJ LLC
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Thanks Scott,
    Good catch with the TC/FC mixup, i will fix it ASAP.
    Regarding the CH (and others levels), currently, if you dont report a measurement for that level, the app assumes 0.
    I am debating the best way to handle when a measurement is not taken...
    - Assume the last valid measurement still applies?
    - Assume the last measurement was invalid (and dont provide advice)
    - Allow the user to globally ingore certain measurements.
    Note, this also has an impact on how the graphs are displayed.
    Since most people dont measure CYA every time they test there pool, should the graph show a "sawtooth", dropping to 0 everytime they dont measure, or should it assume the last recorded measurement for that lavel is still valid?
    Thanks again,
    -Ken-
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Scott,
    I am looking at your TC/FC question again.
    Isn't FC=TC-CC?
    My Measure page records TC and my Advice page shows FC ... TC-CC.
    I hope I don't have this calc wrong, that would be embarrising!
    Yes, FC=TC-CC. Some kits measure FC and CC, other kits measure FC and TC.
    I would assume that if nothing is entered the value is the same as last time. There is some value to globally ignoring certain tests, but that seems more like an advanced setting, and not something that should be done easily or by default when nothing is entered.
    South Central NJ
    3,192
    May have been my error WRT the TC-FC issue. At least in the latest code, I saw it said TC but may have thought it said FC in the previous code. If there was no change there, I brain faulted. If you did change something, thanks!
    I'd like to see a CSI and/or LSI index.
    Please add the ability to set my own targets, similarly to what the pool calc allows. If I want to set up a low pH bath...
    Scott
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Thanks Scott,
    I will add the CSI/LSI index, as well as the ability to set your own targets to my todo list.
  20. Back To Top    #20
    South Central NJ
    3,192
    FWIW, this is going to be one of the most useful Android Apps! :P
    Now it they could only make a waterproof phone.
    Scott
