Thread: dry acid
    dry acid
    I have always used muriatic acid with good results to lower ph.
    I found myself in wal-mart the other day and bought the dry acid they sell.
    the directions call for "broadcasting" the product, but then this is followed with a warning to make sure no undisolved acid is clumped on the pool floor.
    Is there a better way to introduce dry acid into my pool?
    6600 gal IG concrete/gemcoat
    Fresh water
    1 HP motor
    StayRite PLM 100 system 2 filter
    full sun
    Treasure coast, Florida
    Re: dry acid
    It is best to pre-dissolve the dry acid in a bucket of water and then pour that slowly in front of a return jet with the pump running.
    Muriatic acid is normally quite a bit less expensive than dry acid.
