Results 1 to 19 of 19
Thread: 102 degree heat and bleach useage
    treefarmer's Avatar
    May 2011
    Quitman, TX
    26
    Yesterday afternoon I checked the chlorine and it was at 1.5. I added 182 oz of bleach to raise it back to 5. The day before it was at 1 in the morning so I added another 182 oz jug to get it back to 5. In a 48 hour period I had to add 2 jugs. This just seems like a lot. This AM I just tested it and it's holding at 5. Ph had been steady at 7.5 all week until yesterday 7.8 which is ok but I added 2 qts of acid to bring it to 7.5. Here's the rest of my numbers:
    cc 0 TA 100 Ch 320 CYA 40 Borate 40 Temp 90.
    Do you think it's just the heat that's burning it off?
    I've been running my pump at night from 6pm to 7am. I thought it would be easier on the pump and electric bill to run at night. I don't know it that has anything to do with it.
    Tod
    20x40 gunite inground roman shape 7 ft deep end, 1hp hayward main pump, 2hp in-floor cleaner pump for Paramount PV-3,all plumbing 2" sch 40, Nitro wall climber robot, Fiberstars WPC-2, ColorLogic LED lights, Hayward 425 sq. ft. cartridge filter, UltraPure UPP25 UV ozone.
    Re: 102 degree heat and bleach useage
    It's the heat. You use a lot more chlorine when the water is warmer. When manually adding chlorine, running the pump at night saves a tiny bit of chlorine compared to running during the day. With automatic chlorine feed it is the other way around, but in either case the difference is small.
    And your CYA is too low for this time of year, try adding a bit more.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Just down the road from you in Longview and just took my cya to 60. Aerating that pool at night helps too. Cooler water makes a difference. Dropped mine 6 degrees over night. 103 to 104 today ain't gonna be any fun either! Hang in there. Watch that minimum number for sure.
    I run my filter midnight to 8AM, though Polaris and waterfall both come on a few times to mix the pool and keep chlorine in the waterfall. My pool is still almost chilly.
    treefarmer's Avatar
    May 2011
    Quitman, TX
    26
    CYA to 60?? Don't you have to keep your chlorine high with that much CYA in there?
    You do need to raise the FC level a little when your raise the CYA level, not enough for me to call it "high" however.
    Apr 2010
    East Texas
    9,640
    Quote Originally Posted by treefarmer
    I normally keep it at 50 this time of year anyhow. This has NOT been a normal summer so far!
    treefarmer's Avatar
    May 2011
    Quitman, TX
    26
    Thank you for the information. I'll get some more CYA and see if that helps stabilize the FC usage. At least keeping it at 7 it will help keep it from swinging from 5 to 2 or 1 as it has these past few weeks.
    Woodyp, have you found a good place to purchase your CYA in Longview? My wife's office is there, so she goes there frequently. We've been using the Swimming Pool Superstore on the loop by lowes.
    Apr 2010
    East Texas
    9,640
    Exactly who I bought my pool from! I go to the one at the other end of the loop when I HAVE to! (let's just say they don't agree with my pool politics) But I buy HTH stabilizer and conditioner in a 4 lb. container from Wally World. I priced some liquid CYA at SPSS yesterday for grins. 35 bucks a gallon which is good for 30ppm per 10k gallons. Quicker,............but NO thanks!
    In my friend's pool at the beach we used a granulated CYA product from Walmart and later, some from a pool store. The pool store product instructions said to adjust pH to something lower than 7.5, I think the 7.2-7.5 range, then add to the skimmer. We could not do that since the filter was due to be backwashed so we added it to socks. The stuff was really hard baked, and in larger grains than the HTH from Walmart. It took a long time to dissolve, even with us all squishing the socks for several hours. The HTH brand just dissolved itself in a few hours, almost no help from us. Price was close given slight size differences, as I recall.
    Butterfly's Avatar
    South Carolina
    10,045
    Seems we continue to get good reviews about the CYA sold by WallyWorld.
    More powdery and dissolves faster.
    You're done SLAMing when:
    treefarmer's Avatar
    May 2011
    Quitman, TX
    26
    Yes, I was amazed at how fast the CYA from HTH dissolved. I tied it in a sock on the side of the pool about 2pm and 4pm or so I was swimming by it and started squishing it and with a few minutes I was down to just a handful of product that needs to soak a little more. The stuff from the pool store takes almost a full week to dissolve.
    I'll let the pump run 24 hours and tomorrow afternoon test the CYA level and adjust the FC accordingly.
    Alright now, I asked almost this exact same question a couple weeks ago and said I was thinking of raising my CYA (40) and you guys told me I didn't need to raise my CYA. I too am using 182oz bleach per day and temps have been over 100 for 20 days here.
    Doughboy 18x38 AGP buried 2' deep. 18,400 gal. Hayward Power Flo Matrix. Hayward Pro Series High Rate Sand Filter. TF-100 test kit.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Quote Originally Posted by ROTJob
    Your posts list your CYA at 60 and 65, not 40.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Oh. My bad. It dropped since then. So raise it back to 60?
    <blush>
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, that should help. Your daily chlorine loss right now is at 4 ppm FC per day and hopefully at 60 ppm CYA that'll drop to perhaps 3 ppm FC per day unless the weather (and your pool) gets cooler.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I've posted here about squishing a sock of CYA for <3 hours and testing the next day with reliable results. HTH stabilizer from walmart is what I used. It is about 6 years old even.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    Agreed, I always think, "Wow, wonder what my pool is starting to cook up?" when it's at 86 degrees. But, when you're on the BB Method the answer would be .... NOTHING!!!!
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
