Results 1 to 12 of 12
Thread: Would this be a good sequestrant for me?
    Athlon646464's Avatar
    Jun 2010
    Uxbridge, MA
    63
    I'm about to follow the instructions in post #1 here.
    Would this be a good sequestrant for me? It seems like a good deal.
    http://www.amazon.com/Nava-Chemicals-65 ... 003TY0PA4/
    21,100 gallons - Hayward S-180 Sand filter - IG Vinyl - 3/4 HP Hayward Super Pump - Hayward Vari-Flo XL Valve that says rated for 75 gpm on it.
    Re: Ascorbic Treatment to rid Pool of metal stains
    We recommend using sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives. That product is not based on one of those compounds.
    Jun 2010
    Uxbridge, MA
    63
    Thank you for your quick response. I will order some ProTeam Metal Magic.
    I looked at the directions on the back of their container (picture on web site) and saw that it said to keep my PH level at 7.5 for best results.
    Should I still lower my PH to 7.0 or 7.2 anyway?
    I recommend lowering the PH to between 7.0 and 7.2.
    Jun 2010
    Uxbridge, MA
    63
    Thanks. Will do.
    Jun 2010
    Uxbridge, MA
    63
    Quote Originally Posted by mbar
    When the stain is gone, add enough sequestering agent for the volume of your pool - more is better than not enough.
    I have everything I need to begin treatment. My question is about how much sequestering agent to use.
    The directions on the ProTeam bottle call for 1 quart/10k gallons for the initial treatment. My assumption is that is what the AA is for.
    So - should I use the recommended 'maintenance' amount of ProTeam sequestering agent at this step? (3oz/10k gallons once per week)
    AA and sequestrant are two different things. You should add the startup dose of sequestrant and then continue with the maintenance dose as recommended. One you have experience with how that goes, you can try adjusting the dose downward and see how much you really need to use.
    plucky71's Avatar
    Apr 2010
    Michigan
    116
    I used the higher dose. Not sure if that was correct or not?
    Outdoor fiberglass inground 15,000 gallons, Clean & Clear Plus 420ft. sq. filter, 1 h.p. WhisperFlo pump, New water cycler automatic chlorinater(not using), 1996 pool, TF-100 test kit.
    Jun 2010
    Uxbridge, MA
    63
    Thanks again. I'll do it that way and report back here soon.
    Re: Would this be a good sequestrant for me?
    plucky71, adding more is safer than adding too little.
    Jun 2010
    Uxbridge, MA
    63
    Your method to rid my pool of the metallic stain worked like magic! My pool liner looks like it was just installed!!
