Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: Foreclosed pool.
    Foreclosed pool.
    Hi and thank you for taking the time to create this forum, the information is priceless.
    I bought this home that has the green swamp symptom I going to attack this challenge and bring it back to sparkling clear(with all the info readed here). I can be around the pool the first two weeks while we work on the house maybe 3. After that I might only be coming to the house once a week to check that every thing is alright. After reading I see you have to add chlorine every other day if everything else is in check. I was wondering how the PG does it if he only comes once a week? I don't want to use pucks because of the CYA, but do i have other options?
    16,600gl plaster/gunite pool Pentair UltraFlow 1.5HP Pentair Clean&Clear 150sqft
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Re: Foreclosed pool.
    It takes a while for CYA to build up, it's not going to be an overnight thing. 3 most popular forms of Sanitation, Salt Water Generator, Liquid Chlorine, Chlorine Pucks/Tablets/Sticks.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    Thank you, looks like I will be safe for a while using pucks.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    That actually depends on how much cya is in the pool already. You will need to get test results before you will know for sure.
    There hav been more than a few foreclosed swamps here that came with high cya levels needing to be partly drained to lower it.
    Best first move, get a good test kit. And then buy a whole lot of bleach. Post pics, we love watching swamps turn sparkly!
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jul 2011
    125
    If you're in a hurry. Try http://www.poolsupplies.com/cgi-bin/...675_a_7c201110 I swear by the stuff. There are two different size bottles, one for 15,000 gallon pools and one for 30,000.
    I take care of a pool and the guy that owns the house next door was fighting a black lagoon like crazy. He had guest checking in to his condo on Saturday and asked me Tuesday if I could clear it up for him (after I had watched him battle it for 4 weeks) I mostly deal with commericial pools and double the dosage of most chemicals because of the 60+ people that swim in most of my pools daily. CYA was at 50. That same day, Tuesday, I shut the pump off, nuked the pool with 10 gallons of liq Chlorine and hooked the Revive to a garden hose & started spraying. Let set for 48 hours, vacuumed to waste. Friday at noon you could read a dime in the deep in & tell if it was on heads or tails.
    It's a genie in a bottle, removes all phosphates, metals (including copper), any organics & nitrates.
    Yes, the test kit is on his way and will definitely post pictures.
    Wow, that Revive stuff looks like a miracle worker and a money saver. Also you had a the good range of CYA, if mine is to high when I test it I might need to drain/refill to lower it before starting anything. After you waited 48hr with pump off and then vacuum to waste when did you start testing the water for any other adjusment needed?
    Thank you guys your knowledge is appreciate.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    If you are not able to attend to the pool more than once a week you may want to consider either a Liquidator chlorine injection system, a peristaltic pump to inject liquid chlorine, or a Saltwater Chlorine Generator.
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Quote Originally Posted by AquaDoctorLLC
    You've only used it the one time, or had good luck several times?
    I'm always a bit skeptical about these miracle cures....seems like if it worked that good, I'd have read something else about it here. I looked up the MSDS...bacteria and enzymes. Then I googled the CAS number, whatever that stands for, and got several hits including something to break down manure. Maybe it's just that septic tank helper repackaged! I'd be curious to see how bacteria and enzymes remove metals.
    At least you're not advocating Permasalt.
    22,548
    I can't find an msds on the revive product and we're all about not putting things in your pool that you don't know what is or what it does.
    It surely doesn't remove ALL phosphates or metals so that's bogus. It probably doesn't actually remove any metals. If it does anything it probably just sequesters them.
    Richard320's Avatar
    Jan 2010
    18,993
    http://www.sepro.com/documents/Revive_MSDS.pdf
    22,548
    I found that one but wasn't sure it was the one mentioned above. I found a bunch of msds's for revive. Everything from floor wax to hand lotion.
    Quote Originally Posted by zea3
    I think the Liquidator would be my best and less expensive option.
    Quote Originally Posted by Richard320
    He swears by this product, so I'm guessing is not his first time.
    Toneay, check your PM for new message
    Jul 2011
    125
    Quote Originally Posted by Toneay
    The only thing I had to add afterwards was a little more shock.
    No it's not the 1st time I've used it in more then a dozen pools. I know the stuff works. Yes it does remove metals and most not all the phosphates. Went from 2100ppm to 200ppm. So I'd say it is effective.
    You have to vacuum to waste SLOWLY. It almost looks like cotton candy on the bottom of the pool. Well brownish tan beige cotton candy.
    I was thinking on investing on a small battery manual vacuum(like a pool blaster) so that all that waste wont go to the cartridge filter. Also thinking on the future. Might get some more houses with swampy pools. What are your thought on this? Or should I just get a standard vacuum hose and standard vacuum head?
    Jul 2011
    125
    Vac head & pole. I have both and a power vac too. But I clean 10-12 per day.
    Pop the top on your favorite beverage and watch the sun set as you vacuum away. The clean your cartridge filter. Welcome to pool ownership.
    Landscapers have the worse yards, mechanics drive the worse vehicles and pool men don't own pools. The last thing I want to do when I come home from cleaning 60 a week, is clean my own.
    Have you got a leaf rake? Start with that to clean solids out of the pool. Mine has a hard, dust pan like edge which seems to help scooping. Depending on enzymes or even chlorine to dissolve solids is not realistic. Once all trash is clear, the vac its worth using. It cannot do well with sticks and such, but is good for bits too small for nets.
    I would never add sludge cleaning enzymes to a swimming pool, I'd remove the sludge. Then work on clarity with chlorine and filtration. Vacuuming often, to waste if possible, to see what was missed before. Often as water clears there will be a chunk of stuff found in a corner or something.
    If you read through posts in this forum you will find scores of pools cleaned this way.
    I do suggest that you keep good notes of what you added to the pool, it is wise to keep track.
    Ok, guys I started today this adventure.
    CYA=0
    PH=8.0
    [attachment=1:3rwcsh1a]photo_2.JPG[/attachment:3rwcsh1a]
    I adjust PH to7.4 prepare the sock with CYA shooting for 30. Wait for 30min.
    Shock the pool to 12 and brush away and remove all the debri I could with the leave rake wich was allot.
    This is how it looks after 1.5hr. I test again and FC was 10.5 shock again to 12.
    [attachment=0:3rwcsh1a]photo_13.JPG[/attachment:3rwcsh1a]
    I had to leave but will test again in about 3hr and shock accordantly.
  20. Back To Top    #20
    Jul 2010
    Mickleton, NJ
    229
    Look like it's coming a long nicely, keep it up.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
