Results 1 to 5 of 5
Thread: Hello from jpbutler in NJ
  1. Back To Top    #1
    Join Date
    Jul 2011
    Location
    Edison, NJ
    Posts
    3
    Hi.
    Glad I found this site. I have been struggling with algae for a week and a half now and finally seem to be getting it under control. Initially I did the Leslie Pool wallet exercise. After $150.00 and no improvement, I found this site and starting learning what I needed to do.
    thanks
    John
    [center:1v9oz073]25,000 Gal Cement pool
    Hayward 20GPM Sand Filter
    Hayward 1HP pump
    [/center:1v9oz073]
  2. Back To Top    #2
    Butterfly's Avatar
    Join Date
    May 2007
    Location
    South Carolina
    Posts
    10,045
    Re: Hello from jpbutler in NJ
    Hey jp,
    ..........wallet exercise lol
    Welcome to the forum
    TFP Moderator TF100 Test Kit TF100 TestKit YouTube Channel PoolMath
    You're done SLAMing when:
    1)You lose 1ppm or less FC overnight, & 2)You have .5ppm CC's or less, & 3)your water is clear.
    ~ One should not use a sledge hammer to swat a mosquito. ~
  3. Back To Top    #3
    Glad you found your way here. Now spend some time in Pool School and then start playing around with the Pool Calculator. You will see why you need a good test kit.
    23,000 gallon in ground pool with rock waterfall and spillover spa, Aqualink control system, Polaris 380 cleaner, Purex Triton Clean&Clear Plus cartridge filter. Located in The Woodlands, Texas.
    Pool owner since Nov 2008, Trouble Free since April 2009. Happy to help when I can.
  4. Back To Top    #4
    Join Date
    Jul 2011
    Location
    Edison, NJ
    Posts
    3
    I have read all of the pool school a couple of times. TF100 just came in the mail today.
    My FC is sky high at 25. Was kind of winging it cause the OTO chlorine tester didn't go above 5.
    Will retest tomorrow morning. My guess is that it will be significantly lower as I am still killing off algae.
    JPB
    Hayward 1HP pump
    [/center:1v9oz073]
  5. Back To Top    #5
    Join Date
    Feb 2008
    Location
    Denton, TX
    Posts
    5,062
    Welcome to TFP!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
