Results 1 to 9 of 9
Thread: New owner of beautiful green pool
    Jul 2011
    The Colony, TX
    3
    We've just closed on our new home, a foreclosure, with a SWG pool. We have been doing a lot of reading and trying to learn as much as possible as we embark on this adventure, but now we are ready to get started. This site rocks, by the way. It has already been immensely helpful!
    As advised in the "pool school" section, we purchased a recommended test kit, and here are our initial test results:
    FC 0
    PH: > 8
    TA 350
    TA 75
    CYA 0
    Salt 0
    The pool water is fairly clear, but green. Algae, I presume. I will attempt to attach a picture.[attachment=0:eii8ghsl]pool.JPG[/attachment:eii8ghsl]
    From what I have read, we need to shock the pool. I've read the "how to shock" section and my main question is about our lack of CYA (0). Is it best to add stabilizer before we shock?
    • Inground plaster pool (still need to measure)[/*:m:6jnh4use]
    • Jandy CL340 cartridge filter[/*:m:6jnh4use]
    22,542
    Re: New owner of beautiful green pool
    The first thing you need to do is get the pH down to about 7.4. Then add enough CYA to get to about 30 ppm. Then buy more liquid chlorine or bleach than you ever think you'll need. Then start shocking and keep at it till you pass the OCLT.
    At some point you'll need to add salt but you can do that any time.
    Butterfly's Avatar
    South Carolina
    10,045
    After you lower your pH, start shocking using a shock level of 10 (for zero CYA).
    24 hours after you add the CYA, increase FC/Shock levels based on the amount of CYA you added.
    Allow 30 minutes after adding muriatic acid to lower pH before you add chlorine.
    The two do not play well together.
    Always have pump running when adding chems.
    Is that "TA 350" you reported actually the CH #?
    Welcome to the forum
    You're done SLAMing when:
    Oct 2007
    Philadelphia, PA
    86
    The previous posters gave great advice. I want to add welcome to the forums and that pool looks gorgeous. I can't wait to see photos after you get it cleaned up.
    11x27 in ground, vinyl pool
    ~12,500 gal
    PAC FAB (Pentair) Pinnacle 3/4 hp pump
    Pentair 24 sq ft DE filter
    One skimmer, one return (no main drain)
    Jul 2011
    The Colony, TX
    3
    Quote Originally Posted by Butterfly
    *sigh* Yes, can't read my own notes.
    TA - 75
    CH - 350
    Thanks for the info ... hoping to start the party tomorrow, will post how it goes.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Easier if you get the FC up to 10 overnite as suggested.
    Jul 2011
    The Colony, TX
    3
    Picture update of our progress so far....
    It's been challenging, but we are starting to see results. Looking better ....
    We shall keep plugging away.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Dang! 4 days? AWESOME!
    Looks like you aced pool school... :~}
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Butterfly's Avatar
    South Carolina
    10,045
    oh, you have been so quiet, quiet but you pool is transforming!
