Thread: Need to lower TA and raise CYA
    I have a 8500 gal. salt water pool. I tested about an hour ago. These are my numbers.
    FC 3
    PH 7.8
    TA 120
    CH 160
    CYA 50
    I believe I need to lower my TA to 60-80 and raise my CYA to 70-80. Just making sure that this is correct. I am a new pool owner and just wanted to double check that I am doing this right.
    30,431
    Re: Need to lower TA and raise CYA
    Yes, but you shouldn't be in a hurry to do either one.
    Lower your pH down to around 7.2 using muriatic....your TA will come down with it. Then, monitor pH and, if it keeps rising, read Pool School on how to permanently lower your TA.
    50 CYA isn't bad, so I would CAREFULLY bring it up to around 60-70 when you get a chance. You may have to dial back your swg a little.
