Results 1 to 7 of 7
Thread: Dilemma -- Size of Pool
    We built our in ground gunite pool 11 years ago. There were a number of design iterations, and I recall the size started out at 15,000 gallons (a stock design for this company) but as the county messed with our site plan, I recall seeing a piece of paper that showed the modifications reduced the size to 13,000 gallons.
    Unfortunately, the only paper I've retained over the years all shows the 15,000 gallons so I am wondering if my memory is just incorrect. The pool is curvilinear with no straight sides anywhere so its not just a matter of calculating a volume from length, width, and depth.
    Here's the question: if I can't settle this, what number should I use in calculating amounts of chemicals to add, or assessing the outcomes of tests? 15K, 13K, or pehaps the "happy middle" 14K?
    14,000G Gunite pool, 1-1/2 HP Challenger Pump + 1HP Booster Pump, Waterfall feature, Pentair 60 DE Filter, Polaris 360 Pool Sweep
    Manassas, VA
    Jan 2010
    Central Valley, CA
    233
    Re: Dilemma -- Size of Pool
    I had a similar issue and I used the pool calc with trial and error to arrive at the number. Pick a number, say 14k gallons. Add a carefully measured amount of MA or Chlorine to adjust pH or FC. If the move is bigger than expected, lower the guess to 13,000 and try again. If you didn't get the full effect, increase the size in calc to 15,000 and so on until you narrow it down.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    I was told my pool was "about 15,000 gallons." So I used the calculator for 15,000 gallons and kept coming up short. Not by much, but consistent. So I plugged in 15,500 and it got better. At 16,000 everything matched. I've never felt the need to try any higher number, or get it any closer.
    22,553
    As said, pick a number and start with that. Then adjust the size according to the effect the additions have. You'll be able to get it close enough after several additions of different chems.
    Mar 2010
    Spring, TX
    1,082
    I have been trying to figure out the same thing with adding bleach. But when I pick a number and put in what it calls for I was over shoot. When I reduce about half the size it matches up.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    The calculator can't take into account that bleach concentration %'s often vary from the label they are packaged in.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also remember bleach looses strength as it ages, so may be stronger than marked when new, so it will maintain its rated stregth for its intended shelf life.
    Ike
