Thread: Making sure I am testing correctly with TF100 test kit
    Guest
    I bought the TF100 test kit and have been following the directions on the box but I just wanted to make sure I was doing a few of the test correctly.
    On testing the CC it says to put in 5 drops of the R003 and see if the color changes back to red/pink. When I put the drops in it does not change, but today I put it aside while I was doing all the other test and when I was done with them I looked at it and it had turned back to pink/red. So should I be looking for a instant change or should I be waiting 5 min or so for the color change to see if I have CC?
    On the CYA it says to hold the tube at my waist and add until I can not see the black dot at the bottom. Does that mean I should not be able to see black at all or just not be able to make out a clear dot and is there a exact distance instead of around waist?
    Thanks Keith
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Making sure I am testing correctly with TF100 test kit
    Go with the immediate change on the CC test. It will always turn pink if you let it sit.
    The CYA test threshold is when you cannot tell if there is a dot at the bottom or not.
    Here are some pictures and instructions from Taylor: http://www.taylortechnologies.com/Chemi ... ntentID=36
    Guest
    Thanks, that link helped alot.
