Thread: Jandy stain remover
    Oct 2007
    Pearland Texas
    1
    Jandy stain remover
    Has any one used the jandy stain remover I have one spot just below my stairs
    IG pool, 30,000 gallons, Aqua rite turbo SWG system,aqua logic ps8 unit,Midnight sea wet edge satin matrix , hayward 360 sand filter,hayward navigator,tristar waterfall pump,(hayward vs pump hopefully soon)autofill (well water), waterfall-grotto-tile slide. STARTUP oct 20,2007,
    Sep 2008
    Jacksonville, FL
    105
    Re: Jandy stain remover
    I just saw this online and was wondering the same thing. Curious if it is worth it and how good it works.
    16,500 Gallon Plaster, Pentair WhisperFlo WF-26 1 1/2 HP Up-Rated Pump, Pentair Clean n Clear 150 Cartridge Filter, BioGuard Mineral Springs MS-10 SWG, Hayward Navigator Cleaner, TF-100 Test Kit, Apollo Magnetic Stirrer
    30,432
    The issue is to identify the stain first and then take action.
    A picture sometimes helps. A description of the stain is likewise useful.
    A complete set of test numbers is often a great indicator as to the kind of stain you have and what to do about it.
    Guest
    The jandy stain remover is a device for delivering undiluted acid to a stain. You can accomplish the same with a PVC pipe. However, not all stains respond to acid so the first step is to identify WHAT the stain is.
