Thread: CYA banned from pools in NY?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I was helping my friend out who runs a campground in NY State. He wanted to switch from a chlorinator to a SWG system. So I found the system he wanted and gave him a good price. I told him about keeping his stabilizer higher than normal and keep an eye out for the pH level to creep up. He then mentioned that he can't add Cynauric to the pool as it is against the law since it's a public pool. Anyone have any idea if this is true or how to look it up? I thought this was weird since he was using a chlorinator and as far as I know the only chemical that you can put into them is Tri-Chlor which contains stabilizer. By the way the area is Ovid, NY just in case there are state laws and local laws that overlap.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Re: CYA banned from pools in NY?
    South Carolina Dept of Health & Environmental Control has put a similar ban on CA. Last year Max was 150. This year it was lowered to 100. 1st offense warning and it needs to be corrected. 2nd offense (they come back a week later) pool closed until CyA is lowered.
    Most of the commercial pools have switched to SWG or Liquid Chlorine feeders.
    As far as it being against the law. I don't see how any governing body, would ban CyA totally, as it's a important part of balanced chemistry.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    Mar 2007
    San Rafael, CA USA
    12,082
    Subpart 6-1 of the New York State Sanitary Code says the following (bold emphasis mine):
    6.1-11 Treatment.
    (c) Disinfection.
    (1) Disinfection with chlorine. When chlorine gas, calcium hypochlorite or sodium hypochlorite is used to disinfect a swimming pool and the pool water pH is less than or equal to 7.8, the dose of chlorine or chlorine compound shall be sufficient to maintain a concentration of at least 0.6 mg/l free chlorine throughout the swimming pool. When the pH is between 7.8 and 8.2, a concentration of at least 1.5 mg/l free chlorine residual shall be maintained. A free chlorine residual of 5.0 mg/l or a pH of 8.2 shall not be exceeded in any swimming pool during use. All chlorine solutions shall be added to the pool water by chemical feed equipment conforming with standards contained in Section 6-1.29, Item 11.1 of this Subpart.
    (4) Use of cyanuric acid-based chlorine (or any other chlorine stabilizer) is prohibited. Pools found using or containing any cyanuric compound shall be closed, drained and refilled prior to continued use.
    I believe this ban of CYA in commercial/public pools (and spas) in New York State came about as an over-reaction to some outbreak, possibly of Crypto.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Wow, how stupid can they get?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    South Central NJ
    3,192
    He'd be better off with a liquid fed system or a commercial multi cell system like Auto-Pilot has that can meet the elevated demand resulting from the lack of CYA.
    In Pennsylvania, you need a pesticide license to add algaecide if you are a service tech.
    Scott
    Owner of - PoolGuyNJ LLC
    Jul 2011
    125
    Quote Originally Posted by chem geek
    6.1-11 Treatment.
    (c) Disinfection.
    One more reason to live in the south. Justbpicking y'all.
