Thread: Shock in a soft tub?
    I have a soft tub. Can I use the trouble brand shock in this type of tub?
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Re: Shock in a soft tub?
    As long as you brush it around until is is fully dissolved. They make special shock for vinyl liner pools, but you should still think of brushing it. As an alternative, you can add the shock to a bucket of water and stir it until it dissolves and then pour it in the pool. **** SPECIAL NOTE **** ALWAYS, ALWAYS, ALWAYS add any chemical to water, NEVER add water to the chemical.
    Might want to check into using liquid shock, although it raises pH slightly, a lot easier to use.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
