Results 1 to 9 of 9
Thread: Hello From NJ
    Jul 2011
    Kenilworth, NJ
    12
    Hello From NJ
    hello all. newbie on pools and new to this site. excellent site with lots of info. but im so new and lost. just got my intex pool filled, added the salt, circulated for 24 hrs. turned on the salt water generator today and add the cyranic acid as per the intex instructions . my question is, what do i do next. when do i start taking readings, and when can i swim.
    any help will be apreciated.
    danny
    Intex 16' x 48" Ultra Frame
    Intex 2650 GPH Sand Filter
    Intex Krystal Clear Saltwater System CS8110
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Hello From NJ
    Test everything but your CYA now and adjust per pool school. PH and FC most important----------then enjoy!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    Re: Hello From NJ
    Welcome to TFP big D
    Seriously consider investing in a good test kit...please see below for the ones we recommend
    pool-school/pool_test_kit_comparison
    Jul 2011
    Kenilworth, NJ
    12
    Re: Hello From NJ
    Quote Originally Posted by dmanb2b
    thanks for the info, do you have a recomendation on where is a good place online to buy one of those test kits. they seem rather expensive.
    danny
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hello From NJ
    Welcome to the forum
    The fav test kit around here is the TF100 sold by duraleigh (site owner) at http://www.TFTestKits.Net.
    Best bang for the buck and excellent service
    If you post a set of test results, we can help you get started.
    You're done SLAMing when:
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    Re: Hello From NJ
    Quote Originally Posted by Butterfly
    Ditto...more expensive than the typical test strips..yes. The amount of money it will save you knowing your exact chemical levels and how to adjust them vs. getting pool stored with $200 in chemicals that will do nothing, priceless.
    The TF100 is best bang for your buck and his customer service is 2nd to none. Forum Lifetime membership also qualifies you for a discount on the kit.
    Feb 2008
    Denton, TX
    5,061
    Re: Hello From NJ
    Welcome to TFP!
    Jul 2011
    Kenilworth, NJ
    12
    Re: Hello From NJ
    hey all, well i finally bought a cheap test kit from walmart till i order one from the internet this weekend. these are the results i got.
    CL .5
    PH 7.5
    Alkalinity 50
    Hardness 50
    Copper Ion 0
    I am running another boost cycle on my intex saltwater per the instructions to try and get the level up to 0.1 to 0.2. with the levels im getting, can i use the pool tomorrow?
    danny
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Hello From NJ
    Welcome to another Garden Stater! (I grew up in Tenafly, N.J.)
    Use bleach to get your chlorine up initially - don't 'stress' the cell - it's great for maintaining the chlorine, but 6% unscented bleach adds the chlorine less expensively (you can use the pool calc in my sig to figure out dosage)
    I figure your pool is ~ 6600 gallons - 3/4 gallons of 6% bleach should get you to swimmable within an hour. (I don't know your CYA level - and can't assume you have any or enough for a SWCG pool - that's why you need one of the good test kits)
    Luv& Luk
    -Ted
