Thread: Salt Water Chlorine Generators working with Aqualink rs4 -
    In theory all chlorinators should function with automated controls as the control manufacturers do their best to keep things universally communicatable, correct?
    Will the CompuPool Salt Chlorine Generator for Inground pools work with the Aqualink rs4?
    14K gal gunite pool
    A.O. Smith B130 2.4hp motor
    Hayward DE2420L Filter
    Hayward SP3020X25AZ Super II Pump 2 1/2 HP Single Speed
    Aqualink rs4
    AutoClear salt system
    Re: Salt Water Chlorine Generators working with Aqualink rs4
    It is very unusual for a SWG to communicate correctly with a different brand SWG. However, it is not essential that the SWG and the automation system be able to talk to each other. Normally you just wire the SWG so it is only on when the pump is on, and then use the SWG control panel to control the SWG, instead of using the automation system to control the SWG.
