Thread: fc is steady at 2ppm
    May 2009
    Trenton NJ
    497
    I have a salt water gen. and fc is steady a 2ppm and cc is .5ppm. Is this too low. salt water gen is at 100 % and I run filter 12 hrs a day.
    Not sure right now of cya because I just put in 4 lbs a few days ago. It was about 45 last reading.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Sep 2009
    Greentown, IN
    914
    Re: fc is steady at 2ppm
    Not high enough. You need to plug your numbers into the pool calculator to see where you need to be w/a cya of 45. Check your cya levels again a week after you dosed it because it doesn't always show right away.
    Also.. w/CC of .5, I would recommend staying on the higher side of your chlorine recommendations to keep any algae from getting hold... just my 2 cents.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    WIth CYA at 45 and a SWG, and FC level is 2 is just enough. But that doesn't leave you with any margin in case of problems.
    If you raise your CYA level to between 70 and 80 the SWG will have a much easier time keeping up. Your recent addition should bring you to somewhere around 70, so presumably things will start improving soon.
    May 2009
    Trenton NJ
    497
    thanks. lots of rain past few days so I think I may need to add more cya soon but will check first.
