Thread: Pentair IntelliChlor IC15 Cell - 520888
    Looking for a verdict on this salt system. Anyone know anything about it? Pro’s or Con’s?
    Does it work well? Is it reliable?
    14K gal gunite pool
    A.O. Smith B130 2.4hp motor
    Hayward DE2420L Filter
    Hayward SP3020X25AZ Super II Pump 2 1/2 HP Single Speed
    Aqualink rs4
    AutoClear salt system
    susa's Avatar
    Oct 2010
    Deep South
    578
    Re: Pentair IntelliChlor IC15 Cell - 520888
    Appears to work well, friends and family have installed this over the last 6 months but consider getting at least the IC40 as you want to deliberately oversize for longevity and performance.
    Even if my pool is only 14K? Should the 15K work well?
    14K gal gunite pool
    Aqualink rs4
    It depends on where you live and how long you typically run the pump. If you live somewhere very sunny and/or very hot and don't have a longer than average pump run time you will probably need something larger.
    If you live somewhere less sunny and cooler, that unit will work, but we recommend getting something larger, ideally between two and three times as large as what you really need.
    Ok, just so I am clear. I live in Dallas TX. My pump runs 9hrs a day. So the 15K salt system would be to small? I should go up to a 24K? Would that not be too big?
    Thanks in advance for your help
    14K gal gunite pool
    Aqualink rs4
    In TX with a 9 hour run time, the IC-15 would not be enough to keep up on the hottest days or if you had several people swimming.
    Larger is better (up to a point). A 24K unit will work in your pool. However, I recommend getting a system that is designed for a pool between 28K and 40K gallons. The larger unit will be able to keep up easily, will laster longer, and will cost less in the long run (because it lasts longer).
