Thread: ORGANIC Additives
    Jul 2011
    Surf City, California
    24
    ORGANIC Additives
    I am new to the pool maintenance and trying to figure what works. I been trying to figure out the other stuff that the pool stores trying to sell you. One of the big things Leslies Pools always jumps on is the organic additives known as Pool Perfect. Has anyone used this? Is it really needed? is Phosphate build up something is really a problem? Won't a Shock cure this?
    Pool Perfect + PHOSfree
    Clear, Perfect Algae-Free Water... Unconditionally Guaranteed!
    Combines proven phosphate remover with Pool Perfect natural enzymes...all in one concentrated formula. Lower phosphates mean less food for algae while Pool Perfect enzymes eliminate odors keep your filter clean and prevent waterline ring. When used weekly with normal sanitizer levels you'll enjoy clear perfect algae-free water all year round!
    no phosphate build-up = no algae guaranteed*
    greatly reduced pool maintenance
    less filter cleaning cycles
    25-30K Gallon Inground Pool and Spa
    DE-Filter system 60 Sq. ft
    Salt Chlorine generator
    Pebble Bottom
    Variable Speed pump
    30,403
    Re: ORGANIC Additives
    Essentially marketing hype almost all of which is untrue.
    Read ABC's of Pool Water Chemistry in Pool School.
    This forum will open your eyes about pool water maintenance.
    Pool Perfect is an enzyme product for breaking down things that chlorine isn't good at breaking down, like suntan lotion. It is very handy when you have a significant amount of oily buildup in the skimmer, or spill some motor oil in the pool. There is no point in using it at other times.
    As for phosphate removers, as long as you maintain appropriate FC levels, it doesn't matter what the phosphate level is. Why spend money and effort on a product that you don't need?
    Jul 2011
    24
    Great! Thanks for the advise. I am beginning to learn a lot of the hype!
    Pebble Bottom
    Variable Speed pump
