Results 1 to 8 of 8
Thread: Water Conditioner
    Jul 2011
    Surf City, California
    24
    Water Conditioner
    With a Salt system do you use water conditioner? The pool tech that setup the initial water told me to add a conditioner every six months to help maintain the pool. Cuts down on Chlorine loss,,,I heard that with regular systems but not with a salt system.
    25-30K Gallon Inground Pool and Spa
    DE-Filter system 60 Sq. ft
    Salt Chlorine generator
    Pebble Bottom
    Variable Speed pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Water Conditioner
    Quote Originally Posted by code3
    Welcome to TFP!
    We don't advocate adding anything on a time scedule. Test the water and add what is needed. The only thing you know for sure that a SWCG pool needs in the water is salt and CYA. Add those as your test results indicate the need.
    Jul 2011
    24
    Thanks John! This is a great website.
    Pebble Bottom
    Variable Speed pump
    Jul 2011
    24
    I was told the conditioner is to protect the chlorine from UV so I assume it will increase the CYA?
    Pebble Bottom
    Variable Speed pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Conditioner is another term for CYA. So yes, CYA will increase. For a SWG you want CYA around 70-80 ppm. You should not need to add more unless you have a lot of splash out or heavy rain dilution.
    Love TFP? Become a
    TFP Supporter!
    Jul 2011
    24
    So would it be a good idea to add conditioner in a SWG pool yearly?
    Pebble Bottom
    Variable Speed pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Conditioner = CYa = stabilizer. Add it when you NEED it.
    Jul 2009
    Houston, Texas
    9,427
    It would be a good idea to test the CYA annually and add more if needed to reach 70-80 ppm.
    Test at the beginning of the pool season and again after a couple of months, unless you are having problems keeping chlorine levels in the pool, then you may want to test CYA again to rule that out as part of the problem.
    Love TFP? Become a
    TFP Supporter!
