Results 1 to 9 of 9
Thread: Soundproofing Pool filter
    Any suggestions on soundproofing pool pump/filter?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Soundproofing Pool filter
    Is the pump unusually loud or do you want it as quiet as possible?
    Love TFP? Become a
    TFP Supporter!
    Jan 2011
    Albuquerque
    72
    If the pump is not installed yet (or you can remove and reinstall easily), several members have suggested putting a neoprene mat between the pump and the concrete which will cut down on vibration and noise. Outside of this, I'm thinking that you would need to enclose the pump with some sort of noise reducing material (egg crate, more neoprene, etc.).
    Jason
    edited to add: if you do chose to enclose, there might be some exhaust / ventilation required
    Green1340's Avatar
    May 2011
    Kemp, TX- 50 mi. south of Dallas
    55
    A simple wall, lattice with climbing vines or bushes between the pump and the pool would also provide somewhat of a sound barrier.
    Greenhaw
    Freeform Gunite, 21K Gallons, Gray Plaster, 570 sq. ft., 106 Perimeter.
    Pentair- VS 3050, Intellichlor IC-40, 520 sq. ft Cartridge Filter, Intellibrite LED.
    Sun Touch Controller, Legend Platinum Cleaner with Pentair 1.5 hp Booster Pump.
    2- Bubblers & 2- Deck Jets. Autofill & Overflow. TF-100-Test Kit.
    i would like it as quiet as possible
    X-PertPool's Avatar
    Exeter, PA
    1,385
    If it's possible keeping the pump in a room with a door works REALLY well.
    But seriously I have a customer that has a pump house room and it's about a 8x10 room. After running for a week there is a noticeable temperature raise that you can feel when you first open the doors. I'd say about 10-15 degrees higher than outside temperature.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    22,543
    Get a VS pump. On low speeds you'll barely even know it's running. In fact you'll probably have to feel it to know it's on.
    no-mas's Avatar
    Jun 2008
    FL
    405
    x2
    after I switched my motor to a 2-speed, I always paused and looked if I was near the pump pad because it was so quiet compared to the prior single speed
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Quote Originally Posted by X-PertPool
    The room should have a temperature controlled exhaust/ventilation fan.
    Support the site
