Thread: Residential AG Pool Heater -- ASME or not?
    About to finally pull the trigger an order a heater. I will be buying a 400,000 btu RayPak, electronic ignition, natural gas, cupro-nickel heat exchanger. For a few hundred dollars more, I can get those specs and have it be ASME. Not even sure what that is. What are pros and cons of getting that, and if the money is there, should I get it?
    Pool this year and likely next is Intex. After that, probably a "permanent" AG oval if any of that matters.
    Thanks!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    22,551
    Re: Residential AG Pool Heater -- ASME or not?
    I wouldn't worry about it. The only thing you're getting is the paperwork and a "U" number. They're made exactly the same they just don't have to register the ones that aren't certified, so they don't have to pay the fee and generate the paperwork.
    Thanks!
