Thread: adding muriatic acid to pool.
    will somebody tell me how long i should wait to go swimming after adding acid to lower ph. I tried to find an answer for the topic on this,but don't know where to look. Thanks for all help.
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: adding muriatic acid to pool.
    It depends on how much you are adding, but for a quart or two I give it 15 minutes.
    22,550
    I've waited as long as 15 minutes before.
    Jan 2009
    Southern Nevada
    37
    The bottle I have from Lowes says to wait 2 hours after addition to a swimming pool. We have used our pool when I know it is mixed well after brushing the whole pool and letting the pump run on high for half an hour. I try to do it at night when I know we are done for the day but sometimes that isn't possible.
    18,500 gallon, 16' x 38' freeform ig plaster w/ 7 ft spill over spa
    Pentair C&C+ 420 cart, Inteliflo 4 x 160 pump - new plaster on 5/5/09
    no-mas's Avatar
    Jun 2008
    FL
    405
    x2... barely
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
