Results 1 to 7 of 7
Thread: "Salt One" Pool Protect Product - What is it?
    Jul 2010
    GTA, Ontario, Canada
    16
    I've been testing and balancing my water using this site -- thanks for all the help. I'm now purging some of the old products that were left by the original owner (chlorine pucks etc) and came across a product called "Salt One". It says it is "Pool Protect" by a company called "AquaPro" in Ottawa. It's in a big 5 kg (11 lb) tub. Cost was $45.00. I can't figure out what is in the product and if I would have use for it. The specific content(s) aren't listed. It says the following on the label:
    - All-in-one support for salt generator
    - designed to be used once in the spring after pool opening
    - increases sanitizer efficiency protecting from UV rays
    - produces water softness
    - delays corrosion
    - reduces the wear of your salt generator cells
    The pool store wrote the following on the top of the tub for the previous owner: Add 4 full cups to the skimmer. Wait one hour then add 4 more cups to skimmer.
    I wondered if it was stabilizer, but it doesn't look as granular as the stabilizer that I have used in the past. More like a white powder with some chunks.
    What is it? Should I keep it? Use it?
    My current levels are as follows:
    FC = 4
    CC = 0
    pH = 7.5
    TA = 85
    CH = 310
    CYA = approx 35 or 40
    Water looks great.
    I've tried to find the company contact info to call them, but haven't had any luck.
    Canadian Pool newbie!
    Kidney-shaped 16x32, in-ground, SWG, vinyl liner, 20,000 gal [approx. 75,000 L]
    Hayward "Super Pump" 1 HP; Hayward Sand Filter (flow rate 200 L/min [53 G/min]); Zodiac Clearwater LM2 SWG; Jandy heater
    Full sun from 7 am to 7 pm, no trees
    Three young kids aged 5 and under ~~ heavy bather "loads" and lotsa coaching about peeing in the TOILET!
    Re: "Salt One" Pool Protect Product - What is it?
    Sounds like CYA/Stabilizer to me. Not sure I would use it... How old is it?
    http://www.circledspecialties.com
    44,000 IG Salt Pool - Pentair VF, Quad 100, Polaris 280, IC60, 400 Mater Temp
    Jan 2009
    Southern Nevada
    37
    Could it be borates or something like that?
    18,500 gallon, 16' x 38' freeform ig plaster w/ 7 ft spill over spa
    Pentair C&C+ 420 cart, Inteliflo 4 x 160 pump - new plaster on 5/5/09
    22,553
    Sounds like it's a combination of things. Is there a website listed on the container?
    Apr 2009
    Burlington, ON, Canada
    344
    Not 100% sure, but it looks like AquaPro might be Sani-Marc who can be reached at
    Head Office
    42, de l'Artisan Street
    Victoriaville QC G6P 7E3
    T 819 758-1541
    F 819 758-5800
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Jul 2010
    16
    There's no website nor phone number listed. I can't seem to figure out the manufacturer contact info. Maybe I'll call the Sani-Marc people listed above.
    The stuff at least 3+ years old. Maybe I'll just toss it. I also wonder if it is a combo product -- stabilizer plus other stuff...
    22,553
    They're probably going to tell you to toss it since it's more than a year old anyway.
