Thread: Cleaning the view tube
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    My CYA view tube is getting cloudy looking. I rinse it well after testing, but apparently not well enough. Since a grey dot will read differently than a black dot, how to clean it? Acid? Bleach? Ammonia? Anybody got a clue?
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Cleaning the view tube
    No answer, but I thought the same thing last time I tested mine. Actually my thought was that the surface of the tube is etched rather than in need of cleaning, but i'm interested in the responses to this...
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    22,542
    6% bleach should clean it. Fill it up, let it sit a bit, then rinse well.
    Aug 2007
    near the swamp
    806
    we fill it up with bleach(10.5%) and let it sit for a few minutes(will turn a nice shade of yellow), then rinse
