Thread: Have underground leak?
    How do I know if I have an underground leak? My pool does not seem to be losing any water, yet I have an area near the edge of the decking that is always wet. (There is no chance that it is from splashing) I also removed about 1 1/2 cups of sand from my cartridge filter cannister today.
    I simply can't reconcile why the ground is wet all the time.... It has been 100 degrees for several days, yet the ground is still wet. As I said though, the pool does not seem to be losing water beyond normal evaporation.
    I do not have any other water sources near the wet area. The closest is probably 25 feet away and the ground between the pipe and the wet area seems to be dry.
    Any testing ideas?
    18 x 38 IG vinyl modified roman, sand filter, swg, 1hp pump, minimax-nt ng heater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Have underground leak?
    You might dig a hole in the wet area, and if it fills with water test it for CYA to see if it is pool water.
    22,548
    JT has a good idea, and you might also do a bucket test to see if you're losing more than evaporation.
    Where does your rain water drain too? Do you have weeping tile around your house? Is the wet area a low area? Do you have underwater springs in your area? Do you have alot of clay in the soil?
    Brilliant idea about digging a hole and testing for CYA..... willl try that this weekend!
    Thanks to all......
