Thread: Size area required for Intex 24 x 52 round pool installation
    Hello everyone! I recently purchase an Intex 24 x 52 round pool. My backyard is 26.5' x 72'. Can someone tell me what is the minimum area size required to install one of this pools? Thanks!!
    Intex Ultra Frame 24' Round
    Sun-Heater 4'x20' Solar Heater
    Hayward EC-50 D.E Filter
    Apr 2011
    Lynchburg VA
    393
    Re: Size area required for Intex 24 x 52 round pool installa
    I would want a few feet at least all around the pool but you might want to check local county and/or city ordinances to see if there are any rules there you need to follow. A 24' pool in a 26.5' yard sounds a little tight if the pool is a true 24'.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    No, according to another member that owns on of this pools, the pool is less than 24' in diameter.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Hi,
    This pool is just a few inches short of being 24' across.
    Do you have any pictures of your yard?
    26.5' is kinda small for a 24' pool. I would want to be able to walk around the pool with some room. The 20' ultra frame may be a better choice for your yard.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    I,ll try to get some pictures today, weather permitting.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Most towns require at least 3ft to the property line, you'll have less than 2' and although it's an "Intex", most town/state ordinances consider it a permanent pool. Anyhow, the previous advice of checking your local requirements is solid, if anything, at least from a saftey/insurance perspective
