Thread: Pump twice found not running. How to troubleshoot?
    Oct 2010
    Eastern TN
    172
    I had my pump set to run via controller 0700-2100 daily with no problems. Recently I added a low flow run from 0300-0400. Yesterday and today I found the pump not running in the afternoon. When I pressed the pump button on the controller it started. The time is correct. Every day is indicated by the line above the control scheduler. I use the same pump circuit and have it programmed as 1 and 2. We have had a bunch of thunderstorms but no outages as far as I know.
    Am I missing anything? How do I troubleshoot this issue? I don't want to be gone for a week with the pool not running and the SWG idle.
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Oct 2010
    Eastern TN
    172
    Re: Pump twice found not running. How to troubleshoot?
    Another data point. I had superchlorinate on for a few hours each evening before these events. Could this have disrupted the next day's program cycle?
    22,553
    Have you gone back through the programming to make sure something isn't overlapping it?
