Results 1 to 9 of 9
Thread: Lumpy on board
    Lumpy on board
    Just joined after looking through your site. I will be a new pool owner shortly with lots to learn and I see plenty of info here. Great to know there is a place to find so many answers !
    40 1/2 x 20 1/2 vinyl inground - 28,011 gals (~106,000 litres)
    All Jandy equipment
    Aquapure SWG; CL580 Cartridge Filter; 1-AquaGenie, 1-skimmer, 1-main drain
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Welcome to TFP Lumpy. Good luck on new pool ownership. Be sure to post some shots of your build.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    I will, trees coming down in winter (about 40 so I can get some good sun) Dig will be early spring.
    All Jandy equipment
    30,432
    Hey, Lumpy, (love the name!!)
    Welcome. Answers to almost everything you'll need to know about pools here. Suggest you do a lot of reading and asking questions even before your build starts.........it'll really help.
    Butterfly's Avatar
    South Carolina
    10,045
    Hey Lumpy and welcome to TFP! You have come to the right place for your pool needs! We'll be waiting to see your pix this spring on the build! btw, could you talk to some of my neighbors about removing forty or so trees? It would really help! Thanks and again, welcome
    Joyce
    You're done SLAMing when:
    I wish you could send me a few of your trees!!
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Welcome!
    So, have you made any decisions yet as to what type of pool you'll be building?
    If you haven't already, be sure to sign up for the free newsletter too - see link at top of page.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Quote Originally Posted by SeanB
    Welcome!
    Some trees coming down this week. The before and after should be pretty dramatic considering the amount I will remove. I feel a little guilty about removing so many but I have learned what a nightmare all those trees and shade would be. Some are dead and need to go anyway and the falling branches currently pose a hazard for my family.
    The pool will be a free form mountain pond type with vinyl liner. I hope to put in a pool house but will see how much $ I will have to do this. Will be heated by natural gas and I also ordered a polaris 380 and sand filter. The DE filter seems a bit complicated to me and high maintenance along with costs associated with replacing the parts that are not maintained perfectly to spec.
    All Jandy equipment
    Dec 2007
    Central New York
    504
    Quote Originally Posted by The Mermaid Queen
    Welcome to TFP!
    I was thinking the same thing.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
