Results 1 to 10 of 10
Thread: Tooth erosion from swimming..
    Apr 2009
    Burlington, ON, Canada
    344
    I didn't have any clue where to post this, so hopefully The Deep End is ok.
    Has anyone ever heard of this??
    Rapid and Severe Tooth Erosion from Swimming
    in an Improperly Chlorinated Pool: Case Report
    http://www.cda-adc.ca/JCDA/vol-74/issue-4/359.pdf
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Re: Tooth erosion from swimming..
    the pH of the water may be less than 3
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    What a flawed study. They didn't even have pool water to test. They assumed it was a CYA stabilized pool, which it probably was but they don't even know for sure. And who maintains a pool at a ph of 3? What exactly does chlorine have to do with ph anyway in such a case? Assuming that a stabilized pool was so low in ph as to cause extreme tooth enamel failure without a water test is preposterous and hardly worth the time spent to publish the paper.
    What's the follow up on this woman? Anything? The paper suggests it will not be a problem anymore but it did not say that they actually had results.
    Pure ridiculosity... Flawed results. The paper itself states that this is the ONLY case reported so far. Hardly enough to warrant an assumption that it was an untested pool to blame. Out of the billions and billions of people who swim in improperly chlorinated stabilized pools that have low ph's and didn't know it... only one 72 year old woman had tooth enamel loss... EVER????
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Apr 2009
    344
    Found some more
    This one tested the water and found ph of 2.7
    http://www.google.ca/url?sa=t&source=we ... sPcTcF-6-g
    Colgate:
    http://www.colgate.com/app/CP/US/EN/OC/ ... ivity.cvsp
    And, if you ever swim in Thailand...
    http://www.cphs.chula.ac.th/J%20Health% ... _91_94.pdf
    Of course, in all these cases the pool PH was way too low.
    If anything, just a reminder of how important it is to keep your pool balanced, but kind of pointless as everyone at TFP already knows this (or soon will, if they are new here)
    Quote Originally Posted by rcy
    I wouldn't call a PH of 2.7 "way too low", I would call it "way way way way too too too too low".
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Do you mean a different article than that one? I couldn't find that reference to 2.7 anywhere (I even used search for 2.7 in case I missed it).
    The article referenced above actually gives the previous article even less credibility as it was published in 1983 (so Cuba hotel swimmer was NOT the only case so far) and it also clearly states:
    "Tooth enamel does not decalcify in acidic solutions unless the pH is below 6.0 (6). Even at a pH between 5 and 6, hours of cumulative exposure are required for clinically evident decalcification to occur (6)."
    Cuba swimming lady swam for a couple weeks, a few hours a day and as she swam she got water in her mouth and spit it out. This says she would have had to soak her teeth in the pool water for hours on end to get clinically evident decalcification. Her teeth degraded a lot for the amount of time she swam in the untested pool. It was well beyond "clinically evident".
    What's interesting about the second paper is that they at least went back and asked at the pool for records to try to figure out what happened. There were none really, and no one tested ph after the daily test showed "lower than 6.8" to verify that their additions had actually raised ph properly. There is no way to know what the ph of that pool's water actually was during the time of the tooth enamel issues (1982). There ARE a high number of cases reported from that same pool so it's evident that something was going wrong and that the ph was regularly found to be low when they opened and tested the pool for the day.
    Edit: oops, the 2.7 reference was from the second link, not the first. But it still didn't reference a tested pool of 2.7, it just stated that pool water between ph of 2.7 and 7 that tooth enamel erosion is probable. The Thailand pools however... DID have low ph of 3.2something and 2.97 or something like that. How the heck does someone swim in that and not have skin irritation too?
    Not arguing with the possibilities..., obviously low ph can cause enamel loss. I just didn't like the first paper. They didn't write a paper that had much basis, and that I could believe. That always makes me discount a paper's results. Studies should be based on facts, that one had very few actual facts.
    Apr 2009
    344
    From the first link in my second post
    "A water sample, obtained from the pool in September by one of the swimmers and tested by Virginia's Consolidated State Laboratories, exhibited no buffering capacity and a pH of 2.7, i.e., an acid concentration approximately 100,000 times that recommended for swimming pools"
    By the way, I agree with you that the first article really didn't appear too scientific, or well researched - to be expected I guess, since it was written by a dental expert, not a pool/water expert.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Ah... ok. Found it. Sorry, funny that searching for "2.7" didn't find it, but when I searched the first three words of that quote it showed right up. TY!
    It also says there was no buffering capacity... does that mean 0 alkalinity?
    Mar 2011
    Sunny Central Florida
    91
    ROTFLMAO at the idea of a pool having a ph of under 3......
    You know what is even funnier? Coca Cola has a ph of 2.5 and I'd bet WAY more people have that exposed to their teeth than a swimming pool at 3.
    And NASTY, "regularly took in mouthfuls of water, which she spat out between strokes" EW!!! I wouldn't do that in MY pool, much less a public pool.
    IMO, a vegetarian diet is horrid for teeth. Weston Price documented that native peoples that regularly consumed fatty acids (from animal products) had great teeth. I bet that was more to blame for her **** teeth than swimming in some nasty pool for two weeks.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by frogabog
    Yes, it's actually negative. TA becomes zero at around a pH of 4.5 (the actual pH depends on the starting TA level and other buffers present). At lower pH, TA becomes negative since after the carbonate buffer is essentially gone (outgassed) the TA is mostly determined by [OH-]-[H+] which becomes very negative at very low pH.
