Results 1 to 9 of 9
Thread: Help After HUGE Dust Storm
    lovemy3azboys's Avatar
    Mar 2011
    Phoenix, Arizona
    63
    Water was sparkling clean before last night when a huge dust storm came in. Had to backwash filter this am, vacuumed & tested water.
    Here are my #'s
    CYA was 80 yesterday
    FC was only 3ppm this am, suspect flow was reduced causing SWG not to work overnight
    Added liquid chlorine to bring FC to 7ppm, just wanted to bring FC up right away. Now after vacuuming the water is still very cloudy. Question is, should I bring FC to shock level now or just wait & see what happens??
    25,000 gallon plaster dive pool, Eclipse sand filter, 1 HP Centurion pump, Baracuda G3, TF-100 Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Help After HUGE Dust Storm
    Shut the pump off overnight so any remaining dust can settle on the bottom then vacuum to waste. Don't try to filter all that dust out, you may end up loosing more water backwashing multiple times than vacuuming to waste once. After the dust is gone you can do an overnight test to see if you need to shock or not. You may want to check the cell and make sure there is no dust in there as well.
    Love TFP? Become a
    TFP Supporter!
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    We all saw your huge dust storm. We're with you, bro. Don't let the sand grind you down, and have a great, clear pool again soon.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Mar 2011
    Phoenix, Arizona
    63
    Quote Originally Posted by zea3
    Makes sense as the dust does seem to be floating more than it was this morning. Thanks for the advise.
    Mar 2011
    Phoenix, Arizona
    63
    Quote Originally Posted by Water_man
    Dust storm was very strange, cant recall anything like it before... Thanks for the well wishes...
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Anyone from AZ. have pictures of backyards/pools after dust storm?
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Feb 2008
    Denton, TX
    5,061
    Watching that on TV reminded me of when I used to live in west Texas. We would get one of those every couple of years it seemed.
    Jun 2008
    Marana, AZ
    347
    Right now my pool bottom looks like a lake bottom. (Just a little south, in the Tucson area.)
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Another member dealing with this posted a pic of his pool.
    replacing-the-sand-in-my-pool-az-haboob-killed-it-t35460.html?hilit=haboob
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
