Results 1 to 18 of 18
Thread: Replacing the sand in my pool (AZ Haboob killed it)
    Mar 2011
    Tempe/AZ
    117
    So not sure if this was on the news in your area or not but lastnight we had a giant Haboob come through Arizona and it pretty much killed my sand filter. If your not sure of what a Haboob is watch this time laps video http://www.weather.com/outlook/videos/t ... 7888487149 so just imagine what your pool would look like after that. Here is what my pool looked like, you can see the trail from the pool vac, all the dark stuff is dirt/dust.
    Anyways my pool vac will barely move now and I also have a poolskim as you can see in the upper right corner bend there and the poolskim no longer has enough power to suck anything down. I have a sand filter and I ran the backwash about 15 minutes this morning hoping that would fix the problem and it did not. There is still no power for the vac or the poolskim. Even the water coming out of the sand filter through the backwash hose was very weak compared to how it normally is. Should I backwash for even longer? I'm new to owning a sand filter and we have been living in this house for just about 2 months now. The house is old and the pool is old as well. I dont know when or if the sand has ever been changed out of this filter so i'm guessing it's probably about that time.
    By the way I have a Pentair TA-60 or TA-60/600 I can't quite read it.
    Here are my questions:
    Where are their instructions to replace the sand?
    Where do I buy the replacement sand?
    Instead of replacing the sand should I just backwash longer and see if that fixes the problem?
    Any advice is appreciated.
    Eric
    28,000 gallon IG, Plaster Interior
    Hayward Sand Filter
    Pentair Inteliflow VS Pump 3HP
    20+ Years old and use TF Test Kit
    *Pool remodel coming 10/01/14 details to be in new thread
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Re: Replacing the sand in my pool (AZ Haboob killed it)
    WOW! That video was amazing. I'm sorry this happened to your pool, I imagine it is a very rare occurrence. I don't have any advice to offer you... just a little empathy.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    South Central NJ
    3,192
    It didn't kill the filter.
    The 1st few inches of sand, I'll believe.
    Vacuum to waste. A pool sweep helps keep a clean pool clean. Yours is not a clean pool anymore. Manually vacuuming is the fasted, effective way. Alas, it will cost some in chems but thats a lot less than the cost of the filter.
    Scott
    Owner of - PoolGuyNJ LLC
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Your filter should be fine after some maintenance. You probably need to remove some sand/dirt from the filter manually. Vacuum to waste for now and add water to the pool as needed. Balance the pool after all the dirt is gone. Google Pentair T60 owner's manual for more info on your filter.
    Love TFP? Become a
    TFP Supporter!
    susa's Avatar
    Oct 2010
    Deep South
    578
    in addition to the replies you've already received, just a note that down here in hurricane land, we routinely prepare to run systems on backup power and personally I use Honda Inverters which generate pure sinewave 60 hz/123 volts on both legs, max capacity is around 7000 watts so I can easily run entire house as the Pentair IntelliFlow starts up at below 450 watts (prime) and runs 25 GPM (enough to run Poolvergnuegen) at close to 200 watts.
    Pentair sand filters are here
    Mar 2011
    Tempe/AZ
    117
    When you guys say vacuum to waste what exactly do you mean by that? Sorry for not knowing all the lingo. I downloaded the manual and i'm reading through it now. Thanks for the heads up.
    Hayward Sand Filter
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Quote Originally Posted by Matrix311
    Do you have a cartridge filter or sand filter? If sand you multiport will have a "waste" option similar to backwash, filter, rinse etc.
    If to have a cartridge filter. Close the return valve, If you have a drain valve open it. If not remove drain plug. Thread in a 1.5" PVC male adapter and hose adapter and some backwash hose and then start to vacuum.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    Mar 2011
    Tempe/AZ
    117
    Quote Originally Posted by AquaDoctorLLC
    I have a Pentair TA-60 Sand Filter. Also how do I tell which one is which? There are no markings on the multiport because it's ancient and old. Would the waste option be less flowing them the backwash option? There are 2 ways the water leaves the sand filter and exits out the backwash line, option 1 the water comes out slow and option 2 it comes out fast.
    Hayward Sand Filter
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Wow, that much sand I would worry about it building up somewhere in the piping and restricting flow. But I imagine that if the water is flowing fast enough it wont. Definitely vac to waste on that.
    Man if I saw that rolling into the city I would think it was Armageddon.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    South Central NJ
    3,192
    The valve on top of the filter has several settings, some, I am sure you already figured out. There is a Waste setting that sends anything the pump sends to the filter's waste port (i.e. backwash line). Waste is one position clockwise from Filter.
    Scott
    Mar 2011
    Tempe/AZ
    117
    Quote Originally Posted by PoolGuyNJ
    Scott
    Actually I haven't figured it out. There are no markings as to which direction does what. I've taken a photo and maybe you or someone can assist. Right now it's currently on FILTER mode.
    There are several positions, which position is what? We will call filter position 1 and each slot to the right (clockwise) is 2, 3, 4, 5 and 6.
    Filter - Current handle position #1
    Backwash -
    Rinse -
    Waste -
    Closed -
    Recirculate -
    Thanks for the help!
    Hayward Sand Filter
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Hmmm... a google search came up with several vendors that sell a replacement label for the multiport... but none that actually posted a readable pic of it.
    27' round AG
    Mar 2011
    Tempe/AZ
    117
    Here is the link to the manual http://www.pentairpool.com/pdfs/Tagelus ... lterOM.pdf I can't find it in there either unless I'm missing something. Does anyone else have this model or can anyone tell from the picture which position does what? If you need additional pictures or video I can take some and post it up, just let me know.
    Hayward Sand Filter
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    You might look into purchasing the replacement label... several pool places offer it, the prices vary from around $5 to $20. Perhaps someone here has the same type of multiport that can post a pic of theirs.
    27' round AG
    22,549
    [attachment=0:1ngjaftn]Sand Dollar Multiport Positions.jpg[/attachment:1ngjaftn]
    Here one for a Sand Dollar. The positions should be the same.
    Mar 2011
    Tempe/AZ
    117
    Ah darn, well you were just a tad slow. I ran to one of my local pool stores and they had a top piece as well which i snapped a picture of. Thanks for posting this and yes it's exactly the same as mine. Here is the picture I just snapped.
    Here I thought I was properly backwashing it for the past 2 months, unfortunately not. I've been rinsing it everytime. So for the past 10 minutes I've been backwashing and the water was nasty dirty and now it's finally flowing clean water out of the backwash line. After I backwashed I rinsed and then flipped it back over to filter. Now my pool vac is hauling *** again and the poolskim has enough power to suck a tree into it. Thanks for all your help everyone! Case closed.
    Hayward Sand Filter
    Apr 2010
    Buckeye, AZ 85326
    619
    We got smashed up by the same storm in the west valley. I havent seen a storm like that one in a looong time. My pump starts from 7 pm and runs till about 2am. So it was running during the storm. Once things calmed down a little bit I went out and checked on every thing. My skimmer basket was completely full of debris and the pump basket had lots of stuff in it to. I had to empty them both 2 times throughout the night. My pool vac sucked up section of newspaper bringing it to a full stop. I increased my pump run time by 8 hours last night to try and help keep up with the madness.
    Your vac may have some debris in it as well.
    EDIT: glad you go it all sorted out.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    THE POWER OF TFP!!!!
