Thread: Need Advice Quick!!!
    Apr 2010
    Central Illinois
    205
    Hi,
    We are having a deck installed....almost time to start laying top boards. The plan is to go under the railing approximately 1 inch, but where the caps are they go down more than the railing, leaving only about a 1/4 inch gap. Is that adequate? Will replacing the liner be hard? I'm just wondering if I should see if the installer can cut notches for the end caps or else have the wood go only to (not under the railing? Opinions Please!!!!!!
    15x30x54 AquaLeader Sentinelle AGP
    2 HP 2 Speed Hayward SwimPro Voyager Pump
    Hayward SwimPro Voyager 150 sq. ft. Filter
    Hayward H series millivolt 150 btu Heater
    TF-100
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Need Advice Quick!!!
    We built our deck level with the top rail and cut notches around the post caps. We figured if we had to replace the liner this was easier to get at. There are some photos of the deck on our Pool Issues pages, link in my signature block.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    What kind of liner (overlap, beaded)?
    Any risk of the deck shifting due to frost?
    AnnaK's Avatar
    Jul 2007
    1,134
    Beaded liner.
    Pool and deck are 7 years old. Yes, there's been a little shift, about 1/2" in some places. Last year we whittled away some of the wood by a couple of the caps where it was close to touching. The shift has been as a whole, closer to the top rail at the step end and away from the rail at the skimmer end. It has not touched the rail or the caps, hence no push against the structure itself.
    AnnaK
