Thread: steps/ custom inground liner
    Jul 2009
    Fort Wayne, IN
    392
    I'm not sure if it is correct to start this new post, or attach it to one of my previous post, so feel free to move it!
    We have just cleared our backyard and are zeroing in on getting started but now we are stumped again. Instead of traditional steps, we would like the shallow end (3ft) to have one long step the width of the pool. Originally, we were going to purchase a polar pool kit, but it seems that all of their inground pool kits come with steps that jet out. Our other option is purchasing a corner step but that is our last option. Now, we are considering bypassing a kit all together to get what we want. 15 years ago, our neighbor built a cinderblock walled pool with a liner. This would allow us to have the long step, however, that would involve ordering a custom liner. Basically, the step would be made and then the liner would go over it. Can anyone explain to me how I get a liner that goes OVER the steps? Do we build the whole pool and THEN order the liner? Scared to think about an open hole in my yard for 2 weeks+. I'm thinking that the liner would wear terribly at the outer corner of the steps. Also, it would seem that the liner would have so many more seams to go over the steps.
    We would save thousands going the cinderblock route, but it would involve much more labor. Plus the step construction and the custom liner thing. I would love some input to help us decide which way to go.
    Someone down the road has the exact pool that we would like. Theirs was installed by a pool contractor. He was very nasty when we tried to ask a few questions.
    This pool thing involves SO much thinking. Too hot to think. I need a pool to cool off in first.
    FYI, my next topic will be about auto covers if anyone wants to chime in early!
    Theresa and/or Gary
    Complete DIY: 20x40' rectangle. Resin walls, vinyl lined. 33000 gallons. Full width steps. 8' deep. Diving board, slide. Hayward pro series super pump, sand filter. Raypack 336K BTU heater. Main drain, 2 skimmers, 3 returns, 2 amerilite lights with quick change lens Aquamatic auto cover and a partridge in a pear tree.
    Breaking our backs in the hopes that one of our six kids will care for us when we are old ;)
    Aug 2010
    MA
    173
    Re: steps/ custom inground liner
    We went the liner-over-stairs route on our recently completed pool mainly because we did not like the look of the drop-in stairs. We also upgraded to the full end stairs and I think it was probably the best $1800 we spent. People seem to enjoy sitting and congregating/socializing on the stairs and this provides a large area to do so and others can still enter and exit the pool freely. I don't believe the liner needed to be custom ordered as my pool package (dimensions in my sig) was a standard offering.
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    Newpool2011's Avatar
    Jan 2011
    Southwest, MI
    37
    Our builder made our steps then ordered the liner to fit over them. They put 1/4 foam padding under the liner. Here is a picture of them before the liner was installed. They are 10 ft wide and people love to sit on them.
    18x43x28, 32K gal, True L Vinyl IG
    DE Filter, 1.5 HP Pump, Heat Pump, IC40 SWG, Pentair Easytouch, Dolphin Supreme M4
    Jul 2009
    Fort Wayne, IN
    392
    great pics guys!
    mx702,
    This is exactly what we want (except 20x40). Where did you get this pool kit from? Are the steps made out of concrete? Did you install it all yourself?
    Theresa and/or Gary
    Aug 2010
    MA
    173
    My pool was not a DIY. I hired a local PB. The manufacturer he uses is Imperial Pools and my particular kit is the Legacy edition.
    http://www.legacyeditionpools.com/
    The stairs are constructed of steel and are built just like the wall panels. The components are secured using nuts and bolts with bracing placed strategically along the underside for support and anchored with a concrete collar. The pic I provided is from the website referenced above and not actually my pool, but mine look identical to that (right angle corners and all).
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    You should also consider one step the length of the pool at the deep end. We love ours and it's also a great place to sit in the deep end.
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
