Thread: New pool owner and needs help with the levels and such
    I am new to this sight, but have some Questions about my new Above Ground 24' round vinyl pool.
    It has a sand filter, 13,000 gallons of water. Anyway I hope that I am posting this correctly. It did come with a tester, but it only test the Ph and CL-BR. Sometimes my ph is high and so is the CL then a few days later the ph is still hight but no CL. I understand that I must test for the Akalyne. I am purchasing another tester today that will have that. How do I keep the PH and CL always level? I check it every evening. Some days it is fine but we did have a lot of rain for awhile now it is extremely hot out and full of sunshine. I am guessing that the sun is taking away my Cl fast. I am purchasing some Bleach today, Baking Soda, And muratic Acid. Please Advise as to how much to add each day.
    Thanks I do need some help newby of a swimming pool.
    doglady
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: New pool owner and needs help with the levels and such
    Head on over to Pool School. And don't buy any tester until you've read the article on test kits compared.
    Chlorine is a consumable. It gets used up killing bacteria and oxidizing organics (like dead skin and sweat) as well as broken-down by UV rays from the sun. You will need to add daily or every other day, depending on your test results and pool usage.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Welcome to TFP
    Best bet would be to get your own quality test and 2nd best option until you do so is to post a full set of test results from the pool store.
    Reading needed to fine tune your water are FC, CC, PH, TA, CH and CYA.
    Below are the kits we recommend using, I prefer the TF100
    pool-school/pool_test_kit_comparison
    Thank you so much for your replies I appreciate that very much. I am purchasing a new test kit now. As soon as I get it and my results I shall post them more accurately.
    Doglady Thank you again.
