Results 1 to 8 of 8
Thread: looking for a timer
    Jun 2011
    Nj
    57
    looking for a timer
    i would like to setup a timer to run my pool pump and my swg
    was looking around and found
    http://swimmingpooltimeswitch.com/CD-104P.html
    i dont want anything fancy
    just a simple on off
    with a manual override
    all my stuff is 120v
    now for some reason the spst and dtdt is confusing me
    i know with 12v i only need a single
    and a normal light switch is single pole single throw aswell
    so am i right in assuming all i need is the spst setup?
    does anyone know of any place to get a timer cheaper?
    11,000 gal inground fiberglass pool
    Aquarite SWG system
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Re: looking for a timer
    Your local Lowes or Home Depot sale Intermatic and Tork timers. They work great. Expect to pay around $50 for a good one.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    Jun 2011
    Nj
    57
    hmm i did not see any at home depot
    ill have to give it a better closer look
    thanks for the heads up
    Aquarite SWG system
    Most people go with Intermatic, essentially identical to the one you linked to. A similar Intermatic model is just a tiny bit less expensive.
    Jun 2011
    Nj
    57
    thank you
    and as for sp or dp?
    Aquarite SWG system
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Intermatic tripper switches are easier to find for sure.
    22,553
    Here's the rundown.
    SPST - Single pole, single throw - one set of contacts, on or off. (i.e. light switch)
    SPDT - Single pole, double throw - two sets of contacts, one circuit, one set open when the other set is closed. (i.e high/low)
    DPST - Double pole, single throw - one set of contacts on two circuits, both open or both closed at the same time. (i.e. Pump & swg control)
    DPDT - Double pole, double throw - two sets of contacts on two circuits, one normally open and one normally closed on each circuit. Both circuits switched at the same time.
    There are other arrangements but that should be enough to confuse you.
    Jun 2011
    Nj
    57
    right i understand what the spdt all ment
    just had a brain fart
    and couldnt think of a reason why i would need anything more then a spst
    ended up getting one from home depot
    wired it up last night
    thanks for the heads up on HD having them
    Aquarite SWG system
