Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Smart Pool Nitro SmartKleen Universal Review
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Smart Pool Nitro SmartKleen Universal Review NOT RECOMMENDED
    Hello all,
    I'm going to get the Nitro Smartkleen NC22, I've done comparisons with the Nitro NC31/32/51 and it looks like most of the parts are the same (pwr supply, pump, impeller, intakes, bottom lind filter bag, impeller cover, drive tube mount, and drive motor v2) but not the wall climbing models.
    Local merchant has it for $399. I know Cosco has the similar model for $299 and on line can be found between those prices. Merchant has 30 day policy and seem to be pretty good people.
    I'll post a review and some pictures.
    Manufactures produced video: http://www.youtube.com/watch?v=M-lB89AdUkA
    Most of the info seems correct.
    I'm removing my Recommendation. First unit lasted 2 years, 2nd unit lasted 14 months. Comes with a 12 month warranty. (Thank goodness for VISA extended Warranty)
    Last edited by bobodaclown; 06-11-2014 at 02:00 PM. Reason: Recommendation Removal
    Apr 2011
    Murrieta, CA
    2,360
    Re: Smart Pool Nitro SmartKleen Universal
    Initial test. All is ok. I was concerned at first it didn't sink to the bottom, but after a few minutes it settled on the bottom and went about it's business. I had to stop it after an hour and a half, but the pool looked good.
    When I removed it from the pool it did let a little debris back into the pool.I'll try to be more careful when I take it out.
    Emptying the filter is easy. I was suprised by how fine the filter material is. I didn't think I had that much sand/fine particles in the bottom of the pool. They were in the bag along with leaves, small acorns and other debris that falls in daily.
    It surprised me by climbing the wall. I have a concrete pool and where the bottom and sides meet it has a nice rolled transition, the cleaner rolled right up the wall it got about a couple feet up then reversed itself.
    No problem with the pool drain. It states that in the literature and it went right over the drain with no problem.
    Construction. Is plastic. I thought it would be bigger, but its really not bad. It isn't that heavy either. There are two motors, one that drives the roller and one that operates the pump. The pump pumps enough water to keep the front wheels down and really filters/sucks debris well.
    Apr 2011
    Murrieta, CA
    2,360
    We've given it a name, Robey
    Second use went well. Cleaned the bottom of the pool. Shut down after 2 hours. Cleaned filter bag. Collected leaves, small acorns and sand from the bottom of the pool. Upon removal from the pool it does release some fine particles back into the pool. I need to remove slower or figure a better way to remove it. I removed Robey by the skimmer so some of the fine particles get sucked into the filter. It works for me. It's easier than dragging out the hose and such.
    Apr 2011
    Murrieta, CA
    2,360
    Satisfied after a month of usage. Still haven't posed pictures. One small issue, the Velcro whiskers I lost one, contacted the manufacturer and they sent a replacement set. They act as filters trapping debris when lifting the unit out of the water. It's not really a big deal.
    Pros: Low price for robotic cleaner, does the job well, don't have to drag out hose and manually vac the pool.
    Cons: Velcro whisker came unglued from small door (contacted manufacture and they sent replacement whiskers).
    Re: Smart Pool Nitro SmartKleen Universal Review
    I grabbed one of these unit's as well, the Costco version, which appears to mirror same except for the colour, as the blue Nitro being carried by the local pool supply company for $200 more.
    Had it for two week's and doing a fabulous job on the floor (no wall's) of my 20 x 40, 30,000 G, L-shaped vinyl.
    Having the same issue with those whisker things so will see what I can get from manufacturer. I found that if you have one of the port door's filled with dirt, sometimes get a bit of dirt comes out when pulling out of the pool.
    Apr 2011
    Murrieta, CA
    2,360
    Just and update. It's still going strong. We're very happy with the results. We have smaller leaves and acorns. No issues. Overall very satisfied. Well worth the money.
    Apr 2011
    Murrieta, CA
    2,360
    Just an update. All is well.
    Apr 2011
    Murrieta, CA
    2,360
    After approx. 18 months an update:
    The short of it: I'm happy with it. The cleaner does a good job.
    Hello everyone,
    It has been doing a great job getting the leaves off the bottom of the pool, it even picks up some smaller twigs (length of Popsicle sticks but thinner), and acorns.
    When I was shaking out the bag after it had dried, I was little over zealous and it went snap. It still snaps in place and works fine. So no foul, but be careful. Another issue is the power supply connector where the cord to the robot screws in. The mount broke, it works, but need to be careful when connecting/disconnecting the cord. I tried to glue it using black RTV but it didn't last. I don't remember how it broke (dropped?) but the connector isn't hanging out or anything, it's just loose in the mount.
    I still recommend this pool cleaner. Got it for abut $400. I'm happy with it. I'd recommend it to friends.
    The COSTCO version, Kleen Machine, is on sale for $299 including shipping. I have used one for two seasons without a problem but the reviews are all over the place.
    Gary R
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Jan 2013
    Sunnyvale, CA
    108
    Seems like it would pay for itself relatively quickly in Calif given the price of running a 3/4 hp booster pump here all year long....
    24k Gallon, Plastered in ground pool with attached spa
    Pentair 420 cartridge filter with 3HP variable speed Pentair 011018
    Solar panels
    EasyTouch8 with IC40 salt cell
    Aquabot Rapids 4WD
    Jan 2011
    Palawan, Philippines
    21
    If anyone can help......my biggest problem is with very fine sand and dead algae (which is as fine as talcum powder). I've tried a poolblaster max.....useless!
    Can you tell me if the filter bags in robotic cleaners are fine enough to stop the sand and algae from just being re-cycled back into the pool and clouding the water.
    I live in the tropics (Philippines) and my pool is in use all year...in HOT sunshine. Algae is a HUGE problem for me. I can't afford a $500 mistake.
    In-ground 5000 gallon 'fun' pool. Integral 'wall-hung' combined pump/filter unit. 1hp motor. LED underwater lamp. Ozone generator. Floatron ioniser.
    Marooned on a tropical island paradise AKA 'home'.
    Apr 2011
    Murrieta, CA
    2,360
    The filter bag on the Nitro does catch sand, but I'm not sure how well it would catch dead algae.
    Apr 2011
    Murrieta, CA
    2,360
    Ouch. Robie is having an issue. Wants to climb out of the water. It's out of warranty but have an extended one through visa.
    Called SmartPool. There's a repair center (Pinch A Penny) about 40 miles from the house in Lutz. Called there and spoke to Mark. They seem very nice. Drove and dropped the unit off. They'll call me tomorrow with info.
    Visa has been prompt so far with their paperwork.
    Apr 2011
    Murrieta, CA
    2,360
    Received a call from Pinch A Penny (authorized repair) robie needs a new motor, cost $260. Waiting to hear from Visa.
    Apr 2011
    Murrieta, CA
    2,360
    Just an update. Robie has died. Needs new motor. I'll get another one. Found on sale for $299. Visa is paying for a new unit. I'll get another one.
    Aug 2010
    Dallas, TX
    4,052
    My robot lets dirt back in when I remove it too. My solution is to yank the robot out of the pool as quickly as possible and let it drain on the deck. I would go crazy if I didn't have my robot. That's a great price on this one you are reviewing, but too small for my pool.
    Apr 2011
    Murrieta, CA
    2,360
    Received my 2nd Smart Pool Nitro Universal NC22. Delivered cost was $330. Hopefully he'll last longer than the first. I'm expecting to get $290 from Visa Extended Insurance.
    Registered my 2nd unit. He's running as I type this all is well.
    Apr 2011
    Murrieta, CA
    2,360
    Got the replacement and the check from Visa. All is well.
    Apr 2011
    Murrieta, CA
    2,360
    I have to remove my recommendation.
    My replacement unit has died 14 months after it was placed in service.
    More info to follow after I get the RMA and repair estimate.
  20. Back To Top    #20
    Jul 2009
    Olney, MD
    218
    If you bought it from Costco, take it back. They have a great return policy!
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
