Thread: Found the site last week, wish it had been years ago.
    My name is Seamus ( Irish for James )
    Live in Sacramento Ca.
    Pool went Black Lagoon last Fall, emptied except for the last foot since then.
    So tired of the chlorine battle installed SWG.
    cleared out remaining water, disgusting.
    Fresh Water, 600lbs of Morton Pool Salt, Shocked with liquid chlorine,
    cleaned filters
    Two hard weeks of testing, chemicals, running the pump, clean filter again.
    Pool is crystal clear.
    Still need to pumice the sides, but I got some time.
    Need a little more CYA, SWG working good. Three hot days no change in chlorine level
    Thanks for all the great info, going to do the BBB.
    Seamus
    Slainte
    20,000 gal IG Gunite Pool - 1/2hp Hayward North-star Pump SP4005
    Hayward Swimclear Filter C4030 Sta-Rite SR400NA Max-E-Therm Heater, 400-BTU
    Jandy APURE35 AquaPure 35K Gallon EI Saltwater Chlorinator 120/240V - Nitro Wall Climber/scrubber
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Found the site last week, wish it had been years ago.
    Yer getting off to a real bad start here. You MUST post pics when you convert a swamp into a paradise!!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    And Jiminy Cricket, I love your avatar
    You're done SLAMing when:
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Welcome to TFP... I hope a good test kit is on your list if you haven't gotten one already. It is the best money you can spend on your pool.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
