I've been reading a lot of posts about cells going bad and current resistors going bad. My question is, what are the symptoms of each? My MS-10 with T-cell 15 stopped generating chlorine. However, how do I tell which of the two might be causing the problem? My voltage is around 25.5 and my amps are around 5.5. That seems within the normal range from what I've read. However, others reporting the current resistor seem to report a very low amperage. My cell is about 5 years old. Obviously replacing the current resistor would be cheaper. But it'll just waste time if that's not the issue. Do my readings eliminate that possibility?
BTW, great site!
BTW, great site!
