Thread: Heat Snorkel?
    May 2011
    MA
    18
    Heat Snorkel?
    Ok, was at my local pool supply store and happened to see this:
    http://www.heatsnorkel.com/the_heat_snorkel_pro_v.htm
    Anyone have any experience with it? By chance would it work? Price seems high for a just pvc, but if the theory works I figure can probably make it myself for considerably less. Thoughts? Worth the effort?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Heat Snorkel?
    If you just wanna aerate the pool .........you can find one of those goofy looking flower head sprayers ( like I have) for about 25 bucks.
    Re: Heat Snorkel?
    If your circulation is setup correctly to begin with there is no heating advantage to a device like that. Most of the pictures show it in fountain mode, which will actually cool the pool, rather than help heat it.
    Jul 2007
    Suwanee, GA
    528
    Re: Heat Snorkel?
    I don't see how that can heat the pool at all, my pump turns the water over, not the $50 pipe. When spraying in the air it will cool the water as Jason had said. I've made several fountains from off the shelf PVC for cooling my pool. Maybe they ran me a few bucks each.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Re: Heat Snorkel?
    Circulating the heated water lower than where the return jet is won't make any difference?
    I understand the concept of cooling and aeration aspect of using it as a fountain.
    Does anyone have a DIY listing the exact parts (and technique) used to make a fountain? I'm assuming I could easily find the threaded piece to attach to the return jet at the pool store and use PVC products from Menards to finish it.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Re: Heat Snorkel?
    Making a fountain is very simple. You basically need a 1.5" male threaded to slip adapter, some pipe, a few fittings, and an end cap or two. Angle the pipe so it comes above the surface, drill some holes in it to create water jets, and you are done. There are several pictures in the threads linked to in the How To Lower Total Alkalinity article.
